Re: Does this chassis look as if it would work?
Could you explain what you mean by firing off the side? Do you mean against the castle walls or the guardrails? I feel like the majority of teams are going to insure their robot can adequately cross many, if not all of the obstacles. If we can be quick in shooting the ball and running back under the low bar to grab another one, and if we shoot extremely accurately. I see a very effective alliance and team strategy that could be put in place. As they damage defenses they feed balls into the courtyard, we can have them picked up and fired within 5-8 seconds.
Here is our chassis crossing the 4" bump in 2012 with AndyMark 6" mecanum HD wheels. Worked fine on the real thing with a fully loaded robot.
https://youtu.be/jl8pHpCjQtY There were deflector plates at 45 degrees on both sides of the wheels that extended to about 2.5" above the ground. Our wheel modules were clam shells that surrounded the wheel, included the bearings, and mounted our toughbox nano gearboxes. |
I'm personally hoping the reason why you want the interchangeability is some dope strategy... |
We used big mecanum wheels during Breakaway...they did surprisingly well on those ramps. I think bigger ones could probably *manage* to get over most of the defenses.
However, we found out that even the impact of coming down off the Breakaway ramps eventually started bending the heck out of the roller support tabs, eventually jamming them. Later in the competition season a major pit task was fixing all the bent tabs....and at like 400 bucks for a set, we weren't in the position to have spares. I think mecanums would eventually get wrecked in this game. |
#10
