Go to Post I'm not basing success on winning a regional. Success is learning by building the best system you can. In the engineering industries, the best system is the one chosen. - AdamHeard [more]
Unread 10-01-2016, 12:56
Toby Roy's Avatar
Toby Roy Toby Roy is offline
Electrical lead
FRC #6009 (Cyber Heart)
Team Role: Electrical
Rookie Year: 2015
Toby Roy is an unknown quantity at this point
Electrical parts keep breaking!
Hi everybody, I'm new to chief delphi and FRC and I need some help with electrical work. So at the quickbuild, I think the part that broke was the Victor 888 (correct me if im wrong), its the little box that connects the mother board to the motors. So my question is: Is there a way to fix it? Or is there a place that supplies parts like these so we can get them in within the next 2 days? because we need these parts IMMEDIATELY, any help would be great, thanks!
Unread 10-01-2016, 13:08
NWChen's Avatar
NWChen NWChen is offline
Alum
Rookie Year: 2012
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Re: Electrical parts keep breaking!
Hi Toby, welcome to ChiefDelphi. Thanks for posting your question in the Technical>Electrical forum.
In general, electrical problems are most easily and effectively diagnosed if you provide us with as much information as possible. What about the Victor 888 in question seems broken? Can you supply us with a picture of your entire electrical setup, of the Victor 888, or more information (e.g. an unusual sound, no LED light, etc.) about your problem? You can upload pictures using the ChiefDelphi image upload tool or linking to an image on a site like imgur.
To be clear, the Victor 888 is a motor controller that looks like this. It connects the Power Distribution Panel (PDP)(this) to the motors in order to supply a specific amount of power to the motors.
As a basic diagnostic, can you tell us:
  • What color, if any, is the LED light on the Victor 888? It should be blinking or solid orange, red, or green if it's wired correctly and receiving power.
  • What color wire is going into the "V-" screw on the Victor 888? What color wire is going into the "V+" screw? Make sure that the wires between the Power Distribution Panel and the Victor 888 go into the V- and V+ screws.
  • Do you have a cable that looks something like this going into the Victor 888? The black wire should be facing towards the inside of the motor controller.
2012 - 2015 • Team 2601
Unread 10-01-2016, 13:15
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
In addition to what NWChen said:
If you need a part in the next two days, your best bet may be to see if a local team can lend you the part while yours is shipping.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 10-01-2016, 14:45
Toby Roy's Avatar
Electrical lead
Rookie Year: 2015
Thanks for clarifying some things for me Im a rookie so this will take some time to get used to. I don't think it is the Victor 888 but it is the victor SP (http://www.vexrobotics.com/vexpro/mo.../217-9090.html) product (but they all do the same thing, sorry for just figuring that out now). the problem initially was that the red 18 gauge wire wasn't a wire at all! It was just insulation that the manufacturer put there for "decoration" so the 3 prong connector did not have to be redesigned this year. So I got somebody to open the victor up and just removed the insulation completely and connected the black and white wires with more stability. Unfortunately, after the "fixing" happened and we tested the whole electrical circuit, the untouched one was blinking orange (which was what should have happened) and the tamperd one was blinking green really fast, so I took it back to the guy and he opened it again, did some work, then tested it and it started blinking red! He said the part was done for so I held on to it for safe keeping. Was this enough description of the problem or is it too much?
Unread 10-01-2016, 16:54
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Rookie Year: 2013
Jalerre is on a distinguished road
I strongly suggest that you don't disassemble electrical components in the future as it is against the rules (R66). Also it can lead to broken parts, such as your situation.
PS The "3 prong connector" is referred to as a PWM (Pulse Width Modulation) cable.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
Unread 10-01-2016, 17:54
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Actually R66 does allow for disassembly if your intentintion is repair. R66.M:
Originally Posted by FRC 2016 R66 1/10/2016
M.Devices may be repaired, provided the performance and specifications of the device after the
repair are identical to those before the repair.
That said, (to the OP mainly) beware of the blue box that follows:
Originally Posted by FRC 2016 R66 Blue Box 1/10/2016
Please note that while repairs are permitted per the FIRST Robotics
Competition Game Manual, the allowance is independent of any
manufacturer’s warranty. Teams make repairs at their own risk and
should assume that any warranty or RMA options are forfeited. Be
aware that diagnosing and repairing COMPONENTS such as these can
be difficult.
Basically, if you have no idea how it works inside, see if you can swap under warranty first. If a warranty swap isn't doable, I do suggest trying to fix it on one's free time (as learning experience if nothing else) and only using it for practice robot/prototyping purposes (unless you are very, very confident in your repair). After all, if it's broken beyond repair and you aren't able to warranty it out, what have you to loose?
(All of this said, if you DO know how these work and feel qualified to fix it, if you don't mind voiding warranties, go for it, repairing stuff is fun!)
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
Unread 10-01-2016, 18:14
Toby Roy's Avatar
Electrical lead
Rookie Year: 2015
Thanks for all the info, the victor SP is broken beyond repair, so I'll have fun taking it apart and seeing how it works, thank you all so much for your help!
Unread 10-01-2016, 18:16
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
The red wire is intentionally not connected because it is absolutely not required for operation. However, to stay compatible with the PWM standard spacing and connection order, the red wire was left intact.
There is plenty of documentation at vexpro.com on the Victor SP in order to assist in debug.
The Victor SPs are 100% tested before shipment so you, most likely, had an issue with connecting it to the Roborio.
You probably do not need a replacement, jut need to undo whatever the electrical mentor did inside the product.
If you need assistance with any VEXpro product you can always e-mail prosupport@vex.com or call us at 903-453-0802.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 10-01-2016, 17:09
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
What exactly made you want to open the Victor and start changing it's assembly? I'm not trying to judge but I just don't follow the reasoning of this. It was assembled that way intentionally and I don't really see what you gain by manually modifying it. Just seems like a lot of extra work at the expense of risk with no reward.
As mentioned above though, electrical components that you plan to use on your robot cannot be disassembled or otherwise tampered with. It sounds like doing so may have broken it When you get your new ones maybe try following some online tutorials
to make sure you have everything nailed down correctly.
Unread 10-01-2016, 17:24
Toby Roy's Avatar
Electrical lead
Rookie Year: 2015
First of all, thanks to everybody for all the help, it means a lot! Second, it wasn't my idea to open the box, it was the electrical mentor at the quick build who had me do it, we wanted to find if the red wire being a decoration was just a production defect or production design (so it was really just curiosity, it was a really whacky situation). I will look for nearby teams who can lend me some temporary replacement parts and then give them back once our tests are complete, and I will not temper with any given parts now that I know it is against the rules, thank you everybody for your help, you are all amazing!
Unread 10-01-2016, 19:12
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
The Victor SP Quick-Start guide clearly states that the Red Wire is not used on page 3.
... the tamperd one was blinking green really fast,
Most likely when the Victor was re-assembled by the mentor, the B/C Cal button was not inserted correctly. In other words the button is being held down. When a Victor SP is power booted with the button held down, it goes into factory calibration (blinking green until button is let go).
This is explained at the bottom of page 6 of the Victor SP Quick-Start.
...untouched one was blinking orange (which was what should have happened) and the tamperd one was blinking green really fast, so I took it back to the guy and he opened it again, did some work, then tested it and it started blinking red!
So the problem was simply that the LED wasn't matching your expectation? What about motor-drive? Regardless this would have been simple to diagnose and would not have required you to disassemble the Victor SP.
...He said the part was done for so I held on to it for safe keeping. Was this enough description of the problem or is it too much?
I'm not sure how the mentor would know this. Don't assume that without first contacting the manufacturer.
If a product isn't matching your expectation please contact the appropriate support channel. For example, if the Victor SP was purchased from VEX, please contact VEX's support email.
http://www.vexrobotics.com/contact/
You can also contact support@crosstheroadelectronics.com, but we will need to know where the Victor SP was purchased from if you email us.
I totally understand the motivation to take-apart-and-tinker, but it really isn't necessary, we're here to help you!
Unread 10-01-2016, 20:30
evanperryg's Avatar
evanperryg evanperryg is offline
still doesn't like half champs
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
*snip*
There is almost never a reason to open up any of the FRC electrical parts. It's against R66, as somebody mentioned, and the components are usually so reliable that, if they do break, it's probably something that isn't worth fixing, either due to time or cost. We've had a similar thing happen in the past with Victor 884's (yeah, we still have some of those for some reason) and it didn't seem to impact their performance. My personal guess is that it has to do with the calibration of the controller, but we've never really had that affect the controller's function.
I've been doing electrical for my team for 3 years now, so if you have any further questions feel free to PM me! I'm always happy to help.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 11-01-2016, 08:21
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Guys,
You may open electrical components to make repairs under the current rules. However as pointed out above, it does require some skill to get everything back in the right place to allow correct operation. FRC vendors are very helpful and as suggested by Oz and Paul get in communication with the vendor for guidance.
The red wire is part of the three wire specification as it supplies power supply to servos when used in R/C applications and FRC servos. It is not needed for motor controllers since there is a separate power connection and that is why it was not connected in your controller.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 10-01-2016, 16:26
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
+1
Welcome to Chief Delphi, Toby.
Your team is located in Etobicoke. There are many top tier teams in Toronto and Mississauga who are likely to have the experience, knowledge and capacity to help you. The teams leading the quickbuild would be a good place to start. It may be best to meet with them in person so that they can look over your electrical system and help you figure out why you "broke" your Victor. People here on CD are more than willing to help but with some things like crossed wiring or bad connections, it is better to be able to look at it in person.
  #15   Spotlight this post!
Unread 15-01-2016, 11:59
dharg99's Avatar
dharg99 dharg99 is offline
FRC #4633
dharg99 is an unknown quantity at this point
PWM cable system only need the white and black for proper communication... I believe the old motor controllers needed the red for extra power as their ability to send the pwm message was weaker than the new talons and victors
Also one thing I've learned being head electrical on my team is simply don't try if you don't know...
Electrical isn't like programming where you can hit backspace, in electrical things can burn, arc weld, explode, and kill you.
Also I recommend tinning wires to newbs, helps them understand the wires a lot more.
#4633Lyfe
