Re: Electrical parts keep breaking!
I would recommend you don't tin your PWM cables...
Matt,
Can you be more specific? Under what conditions? |
Sorry, I should have said the connectors, specifically the male end (the 3 pins).
The pins are already a semi-tight fit into the female ports, and tinning them shouldn't be needed to make them stay in. Hot glue around the connector would work better for that, if needed. If the pins are being tinned because the signal is acting wonky, the wire itself could be broken at a certain point causing intermittent connections, or the crimping at the connector could be bad. |
I agree that male pins should never be tinned. I also do not recommend hot glue. It rarely works like you want because the parts are too big to get hot enough and the glue will get down inside some devices and lift surface mounts parts off the board.
How does that happen?
I believe it has something to do with rapid expansion and contraction during the application. We won't use hot glue.
The way the motor controllers that I have looked at their schematics work is that the black and white wires are connected to an optoisolator. So all the signal does is light up an LED. |
The red wire is power (not signal). It is needed only when the PWM cable is connected to a low-power servo motor. It is not needed for any of the motor controllers. Quote:
The white wire supplies the actual signal to the motor controller. |
#10
Yes, those motor controllers, however victor SP should not be on that list as the don't use the red wire, it's only there as the stock pwm they get in manufacturing is used for all their products, they just cut the red on the Vic Sp's Last edited by dharg99 : 15-01-2016 at 23:35. |
#12
perhaps you meant it shouldn't be in the list because it's a new motor controller, not an "old" one. |
