Go to Post There are "Problems", and then there are "Solutions". Understand the Problem, and keep your mind open to alternative solutions. Don't get married to a Solution. - rich2202 [more]
Unread 10-01-2016, 14:19
chaparoel chaparoel is offline
FRC #4635
chaparoel is an unknown quantity at this point
Exclamation Pneumatics or Mecanum
What you think is better:
Pneumatics wheels or the Mecanum wheels ?
Why?
Unread 10-01-2016, 14:33
Canon reeves Canon reeves is offline
FRC #4490 (That One Team)
Team Role: Driver
Rookie Year: 2013
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Re: Pneumatics or Mecanum
It depends on your strategy, but:
Pneumatics:
- High traction
- Can act as shocks for the robot when crossing defenses
-Doesn't allow you to be pushed in a direction perpendicular to your wheels
-Allows for simpler drivetrain
-You only have to power two sides of your drivetrain, so better motor
allocation with 3 motor gear boxes
-Can climb over obstacles (depending on drivetrain)
-Defending your tower is always an option if something fails
Mecanum:
-Can strafe
-Can be pushed in any direction
-Likely not enough traction to go up the ramps, and definitely not over the defenses like the moat and bumpy road.
- Less dependable, more to go wrong
-If you use 4 wheels, the most power you can give to each wheel would likely be a CIM and miniCIM, so not as fast as a robot that uses 6 CIM motors in its drivetrain
-Little to no use on defense, most robots can push you around
Your team can choose which ever it thinks is best for your strategy, but I highly recommend not using mecanum wheels. If you think its worth it, just compare it to other drive trains using a decision matrix with objectives such as durability, multi-functionality, ease of build, and complexity.
Unread 14-01-2016, 18:10
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Mecanum:
-Can strafe yes
-Can be pushed in any direction Absolutely not true
-Likely not enough traction to go up the ramps, and definitely not over the defenses like the moat and bumpy road. "Definitely" Have you tested them?
- Less dependable, more to go wrong Absolutely false.
-If you use 4 wheels, the most power you can give to each wheel would likely be a CIM and miniCIM, so not as fast as a robot that uses 6 CIM motors in its drivetrain Maybe
Unread 15-01-2016, 01:21
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
Mecanum:
I just wanted to say that unless you've tested this, it's all just hypothetical.
In 2010, my team used mecanums, and that ramp was a much greater angle than those seen on this year's field. We did not have any issues going up and over.
Don't entirely rely on other people's opinions, make your own judgements based on your experience and testing!
(I will forever have a love for mecanum, but I might be biased since my coffee table is mecanum drive )
Peachtree Regional Volunteer since 2003
Unread 15-01-2016, 03:02
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Partial Quote:...."(I will forever have a love for mecanum, but I might be biased since my coffee table is mecanum drive)"
______________________
Lol...Now I know exactly what "Special Personal Project" I am going to order that wonderful tank chain tread for now! I'm going to turn my living room coffee table into a Stronghold Defense crossing capable coffee table. It may be too heavy for our robot, but it surely isn't for my future coffee table bot.
Our living room is small (the house overall is large though), and we have a matching very comfortable loveseat and large couch and a chair that are all seating position reclining, so everyone is always moving the coffee table a couple inches at a time, all about the center of the room (just a little bit, but I'm always straightening it up later-"anal type A" that I am), as feet get very close to it when reclining.
They will be able to move it about using a tethered controller and their smart devices, laptops, or ipads.
Thank's for that idea. (I would have never thought of doing that....ever!)
Just wait until my glass & tile squares topped wooden coffee table is going over and through all the team edition of the defenses with the practice bot before season end (besides the Low Bar of course), that the students have been putting together all week. (It certainly won't be FRC Legal, as it will certainly violate the 120" perimeter frame rule (I think I will just mount a nicely stained marching dark cherry wooden electronics shelf about a foot below the glass top), and I'm not putting the bumpers on it, or it certainly won't fit our living room space again. (Though I admit that it would look really cool w/ legal 8" each direction reversible Blue/Red bumpers perfectly in the bumper zone on each corner & our Team 60 numbers, so maybe I will notch the wooden legs so they can be added or removed on a whim).
Unread 15-01-2016, 14:11
alicen's Avatar
Zebra Committee
Might I suggest mecanums for this since it is moving in *all* directions,even just a little bit? Seems to solve the issue of lining up your table much more precisely!
Also, I've attached a picture of my coffee table
sorry for cruddy image quality!
Unread 13-02-2016, 00:46
Dominick Ferone's Avatar
Dominick Ferone Dominick Ferone is offline
FRC #5030 (The Second Mouse)
Dominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really niceDominick Ferone is just really nice
Do you sometimes get bored and drive your coffee table around the house?
2010-2013 Team 353 The POBots - Student, 2014-present Alumni.
2014- present Team 5030 The Second Mouse - Mentor and Founder.
Unread 15-01-2016, 03:35
FRC #0060
_______________________
There were a lot of mecanum's in Rebound Rumble and those ramps were a wicked angle, plenty of mecanum's last year in Recycle Rush (is the angle of the ramps really any different this year?) Low Bar, Sally Port, Drawbridge, and Portcullis are all ramped but flat going through Defenses. (If one could push down & climb the Rebound Rumble ramps, one should certainly be able to push down & climb the Cheval de frieze too I'd certainly think). Moat isn't that tough, Rock Wall ehhhhh - I don't know about that 1, or the Ramparts without some killer type suspension added. I wouldn't even attempt to tackle the Rough Terrain without same killer suspension added....Like Monster truck suspension added.
Put Mecanum's in an "X" pattern to shoot though and it does not push around as easy as many think (especially if backed by rail and wall right in front of the opposition alliances RH Drivers Station.
I'm willing to bet we see at least 1 Supershooter this year that figures out how to sit in the Spybot only position and shoots into top goal only (or maybe even top & bottom), using the curveball effect, and has not much of a drivetrain at all (just enough to crawl over to and climb on the Batter to Surround & or Scale and can collect from 2 sides so robot defense against it is a bit lessened.
We will probably see at least 1 Spybot Supershooter without any drivetrain at all...But, that bot will not make it out of the qualifying matches due to not being able to surround/scale the tower...And it will skew the RP results highly at that specific event! (I certainly could be wrong about not making it out of Q matches if it finishes a low team count event top 8 and ends up an alliance captain due to shooting very well and so many others helping them w/ Defense RP's and scoring high by making all shots high and accurate leading to high scoring auto & tele, while others fail to surround/scale against them).
Said bot will never move anywhere once placed in that Courtyard corner except during the last 30 or so seconds of a match. Count on it happening.
** Setting that X pattern once surrounding on the batter. Certainly No Rolling Off.
Unread 15-01-2016, 08:45
TheJoe's Avatar
TheJoe TheJoe is offline
AKA: Joe Neyhart
FRC #0279 (Tech Fusion)
Rookie Year: 2011
TheJoe has a spectacular aura aboutTheJoe has a spectacular aura about
So much this. We had 8" mecanums in 2012 and were very, very fast with lowering and balancing on the bridge.
I also love mecanum wheels, but for our team this is just not the year to bring them out. Larger pneumatic tires or tank treads will be a lot better for our game strategy.
Teams might be capable, sure, but the game rules don't allow it.
Unread 10-01-2016, 15:06
Dumper FTW 435's Avatar
Dumper FTW 435 Dumper FTW 435 is offline
AKA: Ryan
FRC #0435 (Robodogs)
Dumper FTW 435 is an unknown quantity at this point
I don't know why you're limiting to those two options. I think treads are worth considering if you haven't already.
In terms of those two, I would definitely say pneumatics for the same reasons Canon Reeves posted. Most of the advantages you get from mecanums are not going to help you very much this year, and this years fields really highlight the disadvantages of mecanums.
Unread 10-01-2016, 15:37
Demonic_'s Avatar
Demonic_ Demonic_ is offline
Official unicorn spotter
AKA: Stewart Randall
FRC #2491 (No Mythic)
Team Role: Marketing
Rookie Year: 2013
Demonic_ is an unknown quantity at this point
Why?
Pneumatics pros:[list]
Shock absorbers
Better traction
Pneumatics cons:
  • Leaking is a constant threat
Also, you should consider using tank drive. It prevents the wheels from getting tangled too much, and can provide better traction.
Unread 10-01-2016, 15:47
Team34Guy's Avatar
Team34Guy Team34Guy is offline
Controls/Programming Mentor
AKA: Chris Southard
FRC #0034 (Rockets Team 34)
Team34Guy is a jewel in the roughTeam34Guy is a jewel in the roughTeam34Guy is a jewel in the rough
Pneumatics seem to be an obvious answer so far. The tread option is gaining traction(pun intended), but we've had limited experience with them in recent years. I love the maneuverability of the Mecanum, but, as other posters have already mentioned, they will have problems getting over obstacles. Off topic....
but I'm loving Stronghold so far. Our entire team is engaged in this endeavor right now...strategy, scoring, drive selection, etc. WTG First on Stronghold
Unread 14-01-2016, 16:09
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Rookie Year: 1998
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Umm... great discussion, but I think this technical category is intended for fluid power pneumatics: compressors, cylinders, valves, etc.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 14-01-2016, 16:42
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
For this game? I have no idea why you would even consider mecanum wheels unless the only defense you intend to be able to cross is the low bar.
Mecanum wheels are generally poor for traversing field obstacles, and the ability to strafe doesn't help you whatsoever in this game.
Pneumatic wheels are a great choice, but not the only choice for this game. Think about your team's priorities when making this decision.
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
  #15   Spotlight this post!
Unread 14-01-2016, 16:48
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
For sake of discussion, an argument could be made that they help line up with taking shots on the goals and maneuvering around a possible defender in the courtyard.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
