Go to Post We are customers to FIRST. In that comes expectations. I don't want to hear another, "You should be grateful for everything FIRST does" nonsense when FIRST royally screws up. - MikeDubreuil [more]
Unread 10-01-2016, 15:46
serenagh serenagh is offline
Student
FRC #3045 (Gear Gremlins)
Team Role: Mechanical
Rookie Year: 2013
serenagh is on a distinguished road
Running two festos to the same piston
Just looked through the manual, but didn't see a rule that specifically allows or disallows it. Are we permitted to run two festos (through a "T") to the same piston, and fire them at the same time? Our goal would be to increase the volume of air (and thus the speed of the piston stroke), while obeying the working pressure rules.
Thanks.
Team Captain & Founder: FTC #7593, TigerBots
Team Captain: FRC #3045
Unread 10-01-2016, 16:13
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Running two festos to the same piston
Nope, R90 this year and something similar for every year I can remember disallows this. What are you trying to accomplish that needs the extra speed? Look at available solenoid valves, not all valves with the same size fitting flow the same volume of air at the same rate.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
