Crossing, Damaging defenses question
Does a defense count as crossed regardless of which direction it is crossed? In other words, can I cross a defense going towards the opponent, then cross back across either the same or a different defense to damage the latter?
Re: Crossing, Damaging defenses question
Damage is one way (towards opponent) , but you can exit back to neutral the other way then cross and damage again heading toward the opponent a second time.
Thanks.. I was looking for that info and figured it was only one direction.
Considering whether it makes sense to build a bot focused on breaching defenses and delivering boulders to an ally in the opponent zone, then crossing back to neutral for another boulder, rinse and repeat. While you would not necessarily score many points like this (although you could score the low tower like this), you would increase the probability of creating a full breach for 1 QP, and I think would lead to a strong probability of alliance selection if you were very good at this, rather than being a jack of all trades, master of none. |
IMHO, a robot that is great at crossing defenses is not necessarily a fast robot. So, the shooting robot will be spending a lot of time sitting around.
In theory, this teaming might work: 1) Shooting robot 2) Low robot that can go back and forth quickly with boulders via the Low Bar 3) A 3rd robot that focuses on breaching defenses (the low robot can help the 3rd robot breach the draw bridge/gate defense) |
Since the drawbridge and Sally port open TOWARDS the neutral zone, they will have to be opened with either a tricky mechanism to pull them open, or by crossing another defense and pushing them open from the opponent's courtyard, then holding them open so another robot can cross right?
