Go to Post How come the dropped tool ALWAYS rolls under the exact center of the workbench? - DonRotolo [more]
Unread 10-01-2016, 20:00
stratus stratus is offline
None #3512
stratus is an unknown quantity at this point
Error When Attempting to Install the C++ Toolchain on Ubuntu 15.10 Wily
Not sure if this is on my side, but whenever I try to install the new 2016 toolchain on Ubuntu 15.10 Wily, I get an error saying that I have broken packages. I removed the old ppa and updated/cleaned, but still get the error. It also failed to install with a fresh install of 15.10 in a virtual machine. After adding the new PPA and running apt-get update, when I attempt to install I get this:
Code:
stratus@nyx:~$ sudo apt-get install frc-toolchain
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 frc-toolchain : Depends: g++-arm-frc-linux-gnueabi (>= 4.9) but it is not going to be installed
                 Recommends: frcmake but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
stratus@nyx:~$
Unread 11-01-2016, 02:14
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Error When Attempting to Install the C++ Toolchain on Ubuntu 15.10 Wily
There was a bug filed a few days ago https://usfirst.collab.net/sf/go/artf4792
Unread 12-01-2016, 14:04
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
This should be fixed in about 10 minutes once launchpad publishes the rebuild.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 27-02-2016, 18:07
spat's Avatar
spat spat is offline
QDriverStation Developer
AKA: Alex Spataru
FRC #3794 (WinT)
Rookie Year: 2013
spat is on a distinguished road
Just as a helpful note for those having this issue:
In the case that you are running a beta or unsupported version of Ubuntu (I am using 16.04 B1), trying to install the frc-toolchain package will result in the same error as outlined above.
To fix this, you need to manually install libisl13 and then attempt the installation again.
Good luck on the regionals!
When Henry Ford made cheap, reliable cars people said, 'Nah, what's wrong with a horse?' That was a huge bet he made, and it worked. - Elon Musk
