Go to Post I learned about how FIRST really is about so much more than a robot competition, it is about team building and the individual. - Adel Hodiwala [more]
Unread 10-01-2016, 20:53
KyloRen42 KyloRen42 is offline
KyloRen42 is an unknown quantity at this point
Rotation of a part independent of the base
Excuse the MS paint, but:
Is it possible to isolate the yaw of the cylinder on this prism?
More clearly: Is there a mechanical way to have the rectangular prism rotate but the cylinder will not follow it?
For example, the entire system is facing north. The rectangular prism (robot) turns south, but the cylinder has not rotated at all. For any other non-rotation movement, the cylinder obviously still follows. So if it drives north, the cylinder will stay attached and come north with it.
edit: Please purely mechanical, with no gyro sensors etc
Unread 10-01-2016, 20:58
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
Rookie Year: 2007
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Re: Rotation of a part independent of the base
Easiest thing I can think of is to put the cylinder on a Lazy Susan, and hook it up to a motor to turn. Mount a gyroscope to the cylinder, and use something like PID to drive the rotation of it back to zero continuously.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
Rookie Year: 2011
jimbo493 is on a distinguished road
You could use an accelerometer/gyro like the navX board to track the prism, and have a slew ring with a motor to turn the cylinder opposite of the prism. Assuming that the prim is the robot and the cylinder would presumably be a mechanism.
EDIT: rzoeller beat me to it
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
Rookie Year: 2013
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Well, I guess you could put a gyro on the cylindrical component, and assuming the cylindrical thing is on a motor, have it on a closed-loop system to keep it facing at a constant angle.
But maybe that's not what you're looking for if you want something purely mechanical.
Edit: someone beat me to it
Head Programmer / Driver
Unread 10-01-2016, 20:59
Yes, I am looking for pure mechanical. The only way I can think of is to have the cylinder floating on a small reservoir of water, but I am pretty sure that'd not allowed.
Unread 10-01-2016, 21:01
AKA: Ryan Zoeller
Rookie Year: 2007
Without strengthening the Earth's magnetic field, I can't think of a better way.
FRC 2169 Alumni
Unread 10-01-2016, 21:04
jimbo493's Avatar
Quasi Mentor
AKA: Jimmy
Rookie Year: 2011
if you had a swerve type drive you could link of a steering module in some way shape or form, but it would only work in certain turning situations, and is pretty complicated. The best way is probably to just use a gryo, it sound complicated, but is way simpler than a mechanical system, which in itself is not very feasible
Unread 10-01-2016, 21:05
menns menns is offline
AKA: Michel Enns
FRC #1310 (Runnymede Robotics)
menns has a spectacular aura aboutmenns has a spectacular aura about
I was going to suggest floating it in mercury but aluminum and mercury don't get along so well.
Unread 10-01-2016, 21:07
But hey, maybe the reservoir wouldn't count as a switch or contact!!!
Unread 10-01-2016, 21:08
AKA: Ryan Zoeller
Rookie Year: 2007
See part G
FRC 2169 Alumni
Unread 10-01-2016, 21:10
OK maybe we will do it with a gyro then. How would I keep the gyro accurate after we are bumping around over things like the rough terrain, etc? Would it stay accurate within say, 2 degrees over the course of a match?
Unread 10-01-2016, 21:12
AKA: Ryan Zoeller
Rookie Year: 2007
It will drift - the exact amount will depend on how much jostling around you do. I would recommend adding a potentiometer or some sort of feedback mechanism (even just a button based trim control) to correct for when it does drift, i.e. keep a counter that you add/subtract from the reported value based on driver feedback.
FRC 2169 Alumni
Unread 10-01-2016, 21:15
If you've used gyros before, could you give me an example of how bad it could drift?
Unread 10-01-2016, 21:16
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I would just add in a manual adjustment knob on the driver station - let the second driver adjust it one way or the other as needed during the match.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
  #15   Spotlight this post!
Unread 10-01-2016, 21:17
Is there somewhere we can buy a USB knob or something, or do we have to make one? How would you do something like this that could be recognized as a controller by the driver station?
