Go to Post ...UFH nominations are like jello, there is always room for one more. - Barry Bonzack [more]
  #16   Spotlight this post!
Unread 10-01-2016, 21:15
KyloRen42 KyloRen42 is offline
KyloRen42 is an unknown quantity at this point
Re: Rotation of a part independent of the base
Originally Posted by rzoeller View Post
It will drift - the exact amount will depend on how much jostling around you do. I would recommend adding a potentiometer or some sort of feedback mechanism (even just a button based trim control) to correct for when it does drift, i.e. keep a counter that you add/subtract from the reported value based on driver feedback.
If you've used gyros before, could you give me an example of how bad it could drift?
  #17   Spotlight this post!
Unread 10-01-2016, 21:16
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Originally Posted by KyloRen42 View Post
OK maybe we will do it with a gyro then. How would I keep the gyro accurate after we are bumping around over things like the rough terrain, etc? Would it stay accurate within say, 2 degrees over the course of a match?
I would just add in a manual adjustment knob on the driver station - let the second driver adjust it one way or the other as needed during the match.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
  #18   Spotlight this post!
Unread 10-01-2016, 21:17
Is there somewhere we can buy a USB knob or something, or do we have to make one? How would you do something like this that could be recognized as a controller by the driver station?
  #19   Spotlight this post!
Unread 10-01-2016, 21:26
There have been USB breakout boards included in the KoP in the past that let you wire up analog/digital equipment and read it in like a joystick. I haven't looked yet, but I know an ADALM1000 was included in the KoP this year, maybe you can do it with that?
