Go to Post I don't even consider FIRST to be an extracurricular anymore; it is a way of life. - Jaine Perotti [more]
Unread 10-01-2016, 22:26
Robogineer1649's Avatar
Robogineer1649 Robogineer1649 is offline
AKA: Adam Molnar
FRC #1649 (E.M.S.)
Team Role: Driver
Rookie Year: 2012
Robogineer1649 will become famous soon enough
Two Questions
I have two questions/concerns about the rules and the game in general.
1: How does the defense system work in lay man's terms I still do not understand?
2: Are teams going to be able to set up their robots in autonomous knowing where the defenses and what defenses will be chosen? Or, will they set up the robots then the defenses will be placed.
Unread 10-01-2016, 22:29
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Two Questions
I will answer #2 and say you know one match prior to competing.
answer #1 will probably be "read the rules"
Unread 10-01-2016, 22:35
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
Team Role: Leadership
Rookie Year: 2014
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
Re: Two Questions
Read 2.2.2.1 to learn the defenses,
read section 5.5.5.10 to learn how they are chosen.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 10-01-2016, 22:37
Boltman Boltman is online now
FRC #5137 (Iron Kodiaks)
Rookie Year: 2014
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Two Questions
1: Two matches before you pick your own 3 defenses, you already know low bar will always be in position 1 (GIVEN) and audience selection in position 3 (Changes every full round same for both) THEN you select from remaining categories to benefit your alliance against the other.
So in summary Two are set completely out of your control (1 and 3) ...three (2,4,5) will be selected one from each remaining category about two matches before you play, one match before you play you will get a layout of what your competing alliance selected for you.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 10-01-2016, 22:49
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
Rookie Year: 2013
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
Re: Two Questions
Basically how it works (and PLEASE read the rules for more detail) is the following:
When you are #2 in queue for a MATCH, you get to select the DEFENSES that are in positions 2,4, and 5. (1 is always the low bar, and 3 is selected by the audience, once per round - i.e. the time that it takes all teams to play one MATCH). You select the DEFENSES that are on the opposite side of the FIELD. When you move up to queue position #1, the selections of the opposing alliance are revealed to you, and you can strategize based on that information.
There are 4 groups of two DEFENSES each, for a total of 8 possibilities of selectable DEFENSES. The audience selected group is random for the first qualification round, but then proceeds alphabetically. For example, if FMS selects group C as the first audience selection, the second time the audience gets to select, it will be from group D, the next time from group A, etc. This ordering proceeds into playoff rounds as well. The ALLIANCE may not select any DEFENSE from the group that the audience selected, and must select one each from the remaining three groups. They may be placed in any order.
Hope that helps a bit!
- Official Scorer
Disclaimer: I volunteer for FIRST as a referee. All opinions are my own, and do not reflect those of FIRST.
