Go to Post My goal as a mentor is to make myself irrelevant. Is that possible? Probably not. But this is one place I am willing to aim stupidly high. - Ian Curtis [more]
Unread 10-01-2016, 22:34
acrilex acrilex is offline
AKA: Alexandre Croteau
FRC #5179 (Sénateurs)
Rookie Year: 2014
acrilex is an unknown quantity at this point
FRCSim / Gazebo: Publishing an uninitialized message on topic
Hello,
I just installed FRCsim according to the instructions. After starting frcsim with any of the provided worlds, I get multiple "Publishing an uninitialized message on topic" error messages (enough to pollute my terminal, having to kill the process with ctrl+c ASAP when launching to see the init proces). Here is the error:
Code:
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/time]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/dio/1/2/position]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/dio/1/2/velocity]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/dio/3/4/position]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/dio/3/4/velocity]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/analog/2/position]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/analog/2/velocity]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/analog/1]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/analog/3]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/dio/5/6/position]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/dio/5/6/velocity]. Required field [data] missing.
[Err] [Publisher.cc:99] Publishing an uninitialized message on topic[/gazebo/frc/simulator/analog/2]. Required field [data] missing.
I think there is a bug in the WPILIB sim or on my system (tried on two ubuntu, one 14.04 and one 15.04, same bug). Can someone help me figure out the problem?
Acrilex
Team 5179
EDIT: If I start the simulator with no world selected, this happens when putting any robots (goat or gearsbot). Thus, the error seems to be with Gazebo frc simulator functions.
Unread 04-03-2016, 02:14
Peter Mitrano Peter Mitrano is offline
Peter Mitrano is an unknown quantity at this point
Re: FRCSim / Gazebo: Publishing an uninitialized message on topic
FRCSim maintainer here. This is in fact a "bug" of sorts, but it shouldn't effect anything on your end. Does your simulation still work?
