Go to Post The only tool that will work to get our robot done in time will be a prayer rug. - Rick TYler [more]
Unread 11-01-2016, 12:17
msonnier msonnier is offline
Engineering Mentor
FRC #2992 (SS Prometheus)
Rookie Year: 2013
msonnier is an unknown quantity at this point
Scaling via jack up legs instead of "hanging"?
The definition of SCALE is as follows in GM:
"an act performed by a ROBOT, such that at the conclusion of the MATCH, it is fully supported by the TOWER, is in contact with at least one RUNG, and has all of its BUMPERS fully above the height of the low GOALS. (update in manual and fix “at least one RUNG”) "
Ignoring the note at the end with a correction -- that I suspect was supposed to be removed -- here is what I see as the key point that I want to inquire about:
-- It says you must be "in contact with" at least one rung -- does not say you must be supported
-- Says BUMBERS must be above the height of low goals
It seems to be you could perhaps build some "jack up" type legs into your robot which lifts the "frame perimeter" w/ the bumpers in addition to having some lightweight top appendage which "contacts" the rung. Maybe a lot easier then actually doing the pullup.
Google "jack up rig" and look at images for lots of examples in the oil industry of what I am talking about.
Here are some other potentially relevant rules:
From 3.1.4:
A ROBOT has SCALED the TOWER if, at the conclusion of the MATCH, the ROBOT:
A. is in contact with a unique RUNG, and
B. has all of its BUMPERS fully above the height of the low GOALS.
Blue box: The GOAL openings are not designed to be weight bearing surfaces.
Using these elements to SCALE the TOWER is not only in violation of
G12, but is also subject to an additional YELLOW CARD for egregious
ROBOT behavior as described in the final paragraph of Section 3.3.2
Penalty Assignment.
Here is the potential fly in the ointment:
R2 The ROBOT must have a FRAME PERIMETER, contained within the BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT. Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the FRAME PERIMETER.
R22 BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained between two virtual horizontal planes, 4 in. above the floor and 12 in. above the floor, in reference to the ROBOT standing normally on a flat floor. BUMPERS do not have to be parallel to the floor.
So here is the problem-- what does "standing normally on a flat floor" mean? In starting config the bumpers would be between 4 in and 12 in above the floor -- but when my "jack up legs" extend the robot is now jacked 2 feet up off of the batter or floor. In that config the robot -- were it standing on a flat floor -- the bumpers would not be in the bumper zone. Would a design like this violate R2 or R22 as the bumpers would not be in the BUMPER ZONE or perhaps it could be construed as the bumper being attached to an articulated part of the robot (that moves up and down)?
Thoughts?
