Go to Post Most of all, I long to give others a chance to experience what I did with FIRST, to give people from my home town that opportunity, because FIRST really is that once in a lifetime opportunity that so many people dont get a chance to be a part of. It shouldnt be that way. - Jacqui Sutton [more]
Unread 11-01-2016, 13:11
BSV BSV is offline
FTC / FRC mentor
AKA: Travis
FRC #2723
Rookie Year: 2011
BSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud ofBSV has much to be proud of
Use FTC control system to test FRC drivetrain?
Please pardon my ignorance if this question is stupid:
Could one use the FTC control system (android phones, Modern Robotics motor controllers) to test out an FRC drivetrain? I was just toying with the idea in my head, and wasn't sure if it was possible. So this is a thought exercise. I don't trust the new FTC control system enough, yet, to use it on a larger robot that can turn into a runaway. Plus, those USB connections. But, anyway:
It seems like you would just plug in the CIM motors to the MR controller, and it should work, right? They are both 12V.
Or maybe not: Stall Current on the NeverRest 40's (FTC motors) is 11.5 Amps while it's 133 Amps on the CIM motor. MR Controller (http://www.modernroboticsinc.com/cor...r-controller-3) says max 5 Amps per motor. CIM says it's 2.7 Amp "Free Current". I am not sure how to interpret this. Does that mean you'd be okay unless you stall a motor?
Bottom line: what are the odds of frying an MR controller if you hook it up to a CIM-driven drivetrain?
Unread 11-01-2016, 13:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Use FTC control system to test FRC drivetrain?
You can connect an FTC battery with PowerPoles directly to a motor with PowerPoles if you need to test a motor quickly, but I suspect you will not have a good day if you try to run a whole FRC robot off of the FTC control system (for the reasons you already suspect).
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
