Go to Post Having 75% of the drive train without direct connection to the transmission would make me a bit queasy, but then again, I'm not Winnovative. - Taylor [more]
Unread 11-01-2016, 17:13
Guy997's Avatar
Guy997 Guy997 is offline
Le Programmer
AKA: Sam Schwartz
FRC #1339 (Angelbots)
Rookie Year: 2015
Guy997 is an unknown quantity at this point
Broken SFX?
I'm trying to get SFX 2.0 working on our computer. This did not happen in the past, maybe because we installed Java 8, but when we try and open SFX, it doesn't even open. Our programming team has figured out that it needs Java 7 to run, but we are coding in Java 8. When we install Java 7, SFX works but Eclipse does not. Eclipse doesn't even open. Is there a way for us to get SFX 2.0 working again without switching back to Java 7?
Unread 11-01-2016, 17:30
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I couldn't get it working with Java 8 during beta and filed a bug, but there were many other priorities.
Unread 12-01-2016, 10:43
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: Broken SFX?
It should be working, works for me on Java 8 update 60. Can you post the output of a
Code:
java -version
Also the output of
Code:
java -jar sfx.jar
(from the tools directory).
Unread 12-01-2016, 11:53
Rookie Year: 1997
Re: Broken SFX?
Here's what it printed for me (see artf4769 in the beta tracker)
Code:
Using Java 1.8.0_66-b18 and JRuby 1.7.17
NameError: cannot load Java class com.sun.javafx.Logging
          for_name at org/jruby/javasupport/JavaClass.java:1286
   get_proxy_class at org/jruby/javasupport/JavaUtilities.java:34
       java_import at file:/C:/Users/JOE-XP~1/AppData/Local/Temp/jruby7266290731767961735extract/jruby-core-1.7.17.jar!/
jruby/java/core_ext/object.rb:27
               map at org/jruby/RubyArray.java:2412
jruby/java/core_ext/object.rb:22
            (root) at C:/Users/Joe-XPS13-W7/wpilib/tools/sfx-2014.11.01/sfx.jar!/gems/jrubyfx-fxmlloader-0.4-java/lib/
jrubyfx-fxmlloader.rb:39
           require at org/jruby/RubyKernel.java:1071
           require at /C:/Users/JOE-XP~1/AppData/Local/Temp/jruby7266290731767961735extract/jruby-stdlib-1.7.17.jar!/
META-INF/jruby.home/lib/ruby/shared/rubygem
s/core_ext/kernel_require.rb:55
s/core_ext/kernel_require.rb:53
            (root) at C:/Users/Joe-XPS13-W7/wpilib/tools/sfx-2014.11.01/sfx.jar!/gems/jrubyfx-1.1.1-java/lib/jrubyfx/
controller.rb:1
controller.rb:21
            (root) at file:/C:/Users/JOE-XP~1/AppData/Local/Temp/jruby7266290731767961735extract/jruby-core-1.7.17.jar!/
jruby/kernel19/kernel.rb:1
  require_relative at file:/C:/Users/JOE-XP~1/AppData/Local/Temp/jruby7266290731767961735extract/jruby-core-1.7.17.jar!/
jruby/kernel19/kernel.rb:24
            (root) at C:/Users/Joe-XPS13-W7/wpilib/tools/sfx-2014.11.01/sfx.jar!/gems/jrubyfx-1.1.1-java/lib/jrubyfx.rb:
40
              load at org/jruby/RubyKernel.java:1087
            (root) at /C:/Users/JOE-XP~1/AppData/Local/Temp/jruby7266290731767961735extract/jruby-stdlib-1.7.17.jar!/
s/core_ext/kernel_require.rb:1
s/core_ext/kernel_require.rb:135
            (root) at file:/C:/Users/Joe-XPS13-W7/wpilib/tools/sfx-2014.11.01/sfx.jar!/sfx/lib/main.rb:15
error: org.jruby.embed.EvalFailedException: (NameError) cannot load Java class com.sun.javafx.Logging
Unread 12-01-2016, 14:08
WPILib Developer
FRC #0190
Rookie Year: 2010
Re: Broken SFX?
Joe, was that copied from the tracker? If so, try it again now, SFX was updated in the last week.
Unread 12-01-2016, 16:42
Rookie Year: 1997
Re: Broken SFX?
Sorry, I missed that. It does work for me now when run from the tools directory. However, the eclipse plugins launch from the old location and don't work.
Unread 13-01-2016, 17:50
Guy997's Avatar
Le Programmer
AKA: Sam Schwartz
Rookie Year: 2015
Re: Broken SFX?
We have exactly the same error as Joe Ross. Even when we update SFX and uninstall+reinstall all the NI software, we get the same error. Is there a possible fix for this? We are using Java 8 Update 65.
Unread 14-01-2016, 01:05
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Broken SFX?
The correct version of SFX has a sha1sum of the total zip of 347c0ee66cf120adf5bb9a48f426dc0969e82766
and a sha1sum of the internal sfx.jar of c469e52941d0a121907026b0f2bc5d221a516eab.
Running it has a build ID of:
Release/Built? true Version Identifier: jenkins-SFX-42-42-c6c3c5118c391af8bd0faf54c9713f8e89806c6e
Are these the versions you are running? The most recent version is available at http://first.wpi.edu/FRC/roborio/mav....11.01-zip.zip
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 14-01-2016, 09:45
Guy997's Avatar
Le Programmer
AKA: Sam Schwartz
Rookie Year: 2015
Re: Broken SFX?
Thank you! It works now. We still had the 2014.11.01 version installed somehow...
Unread 14-01-2016, 18:28
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: Broken SFX?
There was a bug with the eclipse plugins that Joe fixed via a patch that will be in tomorrows update. Before that it was loading last years version of sfx if it was still installed on your computer. The patch will make it launch this years version.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 17-01-2016, 16:55
AbsoluteZero AbsoluteZero is offline
FRC #2415
AbsoluteZero is an unknown quantity at this point
Re: Broken SFX?
I was having the same problem until I updated my eclipse libraries and downloaded this year's sfx and when I run it in the command prompt it works, but upon opening up DS nothing happens. This is the command prompt error I get:
C:\Users\student>java -jar C:\\Users\\student\\wpilib\\tools\\sfx.jar
io/console not supported; tty will not be manipulated
Using Java 1.8.0_66-b17 and JRuby 1.7.23
Release/Built? true Version Identifier: jenkins-SFX-42-42 c6c3c5118c391af8bd0faf
54c9713f8e89806c6e
WARNING! Double loading detected! Please make note of this if you report bugs!
Unread 01-02-2016, 09:30
SndMndBdy SndMndBdy is offline
FRC #3419
SndMndBdy is on a distinguished road
Re: Broken SFX?
I've gotten the SFX dashboard working in our environment, including grabbing the latest version from the link above. However, the playback feature doesn't seem to work. When I hit the green triangle button, the screen shifts into playback mode, but the controls for playback don't appear. Has anyone seen anything similar? There are no errors on the command line. I'm running java 8 on Windows.
