Go to Post The great thing about posting questions here is everybody can see the answers. - Kevin Thorp [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-01-2016, 19:05
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
KOP Chassis axle bolt issues...
We had two of our axle bolts that didn't fit through any of the bearings. The bearings measured to spec, but the bolts were oversized for the bearing whole by .008". Anyone else notice this? A quick trip to the flap wheel solved our issue but we had to remove a lot of plating for almost an inch past the threads.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 11-01-2016, 19:08
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Re: KOP Chassis axle bolt issues...
Had same problem on Saturday. Hit them a bit with a belt sander and problem was solved.
The views expressed are mine and should not be construed to represent the views of anyone else.
