Go to Post Having a spare arm that you can put on in 5 minutes or less intimidates the hardware into not breaking. - ChrisH [more]
Unread 11-01-2016, 19:10
Team5709 Team5709 is offline
FRC #5709
Team5709 is an unknown quantity at this point
Question Frame?
Hello everyone this year my team is making a fram and we want to use aluminum 2 x 1 inch tubing but we are not sure how to connect them. any help is appreciated!
Unread 11-01-2016, 19:59
TomBuchler TomBuchler is offline
FRC #0070
TomBuchler is an unknown quantity at this point
Re: Frame?
You can make small 90 degree brackets and attach them to the frame. Or you can go to your local hardware store and purchase some "angle iron" and cut them to the right size and bolt the frame together that way. There are tons of different ways to do it.
Unread 11-01-2016, 20:03
Nathan M's Avatar
Nathan M Nathan M is offline
Team Captain
FRC #0865 (Warp 7)
Rookie Year: 2014
Nathan M is on a distinguished road
Re: Frame?
Vex Pro is a useful resource to learn how to use 2 by 1 correctly, and the 2 by 1 from them is pre drilled.
http://www.vexrobotics.com/vexpro/?ref=logo
Unread 11-01-2016, 21:02
abigailthefox's Avatar
abigailthefox abigailthefox is offline
FRC #1711 (Raptors)
Rookie Year: 2015
abigailthefox has a spectacular aura aboutabigailthefox has a spectacular aura about
Re: Frame?
If you have access to a machine shop, welding is always an option
Unread 11-01-2016, 21:23
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Frame?
Versatubing as was suggested, or at least gussets.
If you have not made a tubing drivetrain before I would do it in the offseason. Lots of things that can go wrong.
<Now accepting CAD requests and commissions>
Unread 11-01-2016, 22:20
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Frame?
Almost the same way you might connect two pieces of wood. You can put a piece of wood inside the tube for a few inches to reinforce the end and give you something to screw into. It should be a tight fit, but not so tight it splits the tube open.
There are many other ways too.
Unread 11-01-2016, 22:43
FRC #5709
Re: Frame?
Thanks everyone very helpful we do have a welding shop and several mentors that have worked with tubing before so i think we can pull it off if we plan it right and build it right!
Unread 12-01-2016, 00:57
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Frame?
well welded frames also tend to be stronger, which is quite a good idea for this game
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-01-2016, 01:46
13spangs's Avatar
13spangs 13spangs is offline
AKA: Jack Spangler
FRC #1756 (Argos)
13spangs is an unknown quantity at this point
Re: Frame?
Rivnuts and gussets all the way FRC is a game of adaptations welding is long ,permanent, and warps. we stopped welding our frame after 2013 and its worked out really well for us. last year week 4 we realized our frame needed to be widened by half an inch. If it would have been welded we would have been stuck.
Unread 12-01-2016, 01:50
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Frame?
However, poorly welded frames can reduce the strength of key joints by a significant amount. Losing your temper with 6061 tubing is a huge difference in all measures of strength.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 12-01-2016, 08:08
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
Rookie Year: 2012
James Juncker will become famous soon enough
Re: Frame?
Welding is a good option IF you have access to it. as well if a well breaks at competition for any reason you have no way to quickly re weld and get your robot up and running again. I would highly encourage having a back up pre planned for any issues in your frame.
The next best option this year will probably be Gussets with 10-32 bolts through. With rivets and gussets you have the ability to determine which rivets or even bolts shear and replace the part with a larger bolt, or replacing the rivet with a small bolt.
with the amount of abuse that I see coming from defenses so far a very strong frame is going to be necessary this year in order to prevent bots from breaking every match.
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
