Go to Post It takes a village to raise a robotics student... - Bob Steele [more]
Unread 11-01-2016, 19:58
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Maximum bore/stroke length for cylinders?
My team was considering using some 2" bore 36" stroke length pistons for the wall scale this year. Would these be legal? I see nothing in the manual regarding max stroke/bore length, nor can I find anything more recent than 2005.
Thanks so much!
Unread 11-01-2016, 20:01
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Maximum bore/stroke length for cylinders?
Legal? Yes. But, legal does not mean a good idea or practical. While large pistons may seem like a good idea, I'd recommend calculating the amount of air needed to actually use them.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 11-01-2016, 20:08
FRC #5202
Of course. I just wanted to make sure there wasn't an issue with using them.
According to the 2015 pneumatics manual, at 60 psi something of this size could lift 170 lbs. The volume needed would be ~113.1 in^3, or 1853.4 ml. This would mean we'd need four air tanks to fill one piston. Doesn't seem /too/ terrible. It's definitely doable.
Unread 11-01-2016, 21:41
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
First:
"It's a cylinder, not a piston"
Brought to you by the IACNAP campaign.
Secondly, if you are pulling the rod back into the cylinder to lift, the area of the piston (yes that's correct) is reduced by the area of the rod.
Unread 11-01-2016, 21:54
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Caleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond reputeCaleb Sykes has a reputation beyond repute
Get single acting pistons if you can, otherwise you'll need 8 tanks.
Unread 11-01-2016, 22:15
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
well not necessarily, you could plumb it so one side is at a lower psi right?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 11-01-2016, 23:03
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Have you found anyone who sells these? I'm sure they have them but remember that it might be the heaviest single part of your robot and will definitely take away from your weight/pneumatic budgets.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 11-01-2016, 23:09
Of course there are alternatives. I was assuming the same pressure on both sides because that is the simplest arrangement.
Unread 12-01-2016, 00:33
FRC #5202
Yep. Ours is double acting, but we could get away with firing it once using 4 tanks, yes?
Our coach acquired them through the typical BIMBA voucher in our rookie season. He had no idea how large they were and we've just had them laying around. I took a look and thought they might be effective for this year.
Unread 12-01-2016, 00:38
Imaginary Friend
AKA: Kevin Li
Team Role: Student
You could fire only once if you spring loaded the return/lift motion
Kevin Li
596 - Sciclones
Unread 12-01-2016, 00:47
FRC #5202
Makes sense.
Unread 14-01-2016, 08:53
CryptoStorm's Avatar
CryptoStorm CryptoStorm is offline
EIC Tech
AKA: Joshua Stilwell
FRC #5056 (MegaHurtz)
CryptoStorm is an unknown quantity at this point
you don't really need to worry about the volume of your tanks as you need to worry about the volume of your pump and the diameter of your tubing.
filling a cylinder like that with 1/4" tube would take forever.
Unread 14-01-2016, 16:03
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Rookie Year: 1998
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
You could use smaller bore cylinders if you added powerful constant force springs (free from Vulcan Spring).
For example, if you pre-loaded your lift with 40 or 50 lbs of force then you have to push the springs up when you're extending, but only have to pull 70-80 lbs when retracting.
Of course you want to design in a fudge factor for safety.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 03-02-2016, 08:39
AMRW1518's Avatar
AMRW1518 AMRW1518 is offline
FRC #1518 (Raider Robotics)
Rookie Year: 2012
AMRW1518 is an unknown quantity at this point
Our Team tested this cylinder with ~120 in^3 of storage capacity lowering and lifting 135lbs. Here's a video link of the test:
https://youtu.be/M5YBYYYhEY0
We used the pneumatic system from last years robot to get an idea of the air flow and the load on the compressor.
  #15   Spotlight this post!
Unread 03-02-2016, 09:04
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
1518's video seems to confirm this
