Go to Post Overpowered? You only took out half the building... Knock the rest down then get back to me. - sodizzle [more]
Unread 11-01-2016, 21:48
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
Rookie Year: 2013
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
Camera image and Network Tables
How would I go about sending the current image from a IP Camera in Labview to the driver station computer? I would like the ability to interface Python Network tables with the IP camera on a robot.
Unread 11-01-2016, 22:49
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Camera image and Network Tables
Typically, the Driver Station laptop requests a video stream directly from the IP camera.
A working example is in the default Dashboard project.
Unread 13-01-2016, 06:33
Yes, you don't really want or need to put entire images into network tables.
The dashboard and LV framework code support a number of ways to get images from robot to dashboard.
If using an Axis IP camera, configure it,plug it into the robot radio, and on the dashboard choose IP on the camera selector. The communication is direct between dashboard and camera and the roboRIO isn't even involved.
If using a USB camera, plug it into the roboRIO and choose between the USB SW or USB HW. Both should work, and the primary difference is the configurability and CPU usage tradeoff.
If you then want to process images on the roboRIO, the Vision Processing VI can be modified to also request images from the camera and process them. The resulting data, likely coordinates, distance, etc. are the type of data you'd want to send through network tables.
Greg McKaskle
