Go to Post I will read this blog, read your stories, learn from you, and be a better mentor because of you. You give me hope. Your diversity brings me joy. - Carolyn_Grace [more]
Unread 12-01-2016, 14:43
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
Large Reduction Single Speed Gearbox
Are there any single speed COTS gearboxes with a reduction of around 22:1-25:1? So far the largest reduction I've seen is the WCP SS Gearbox, which can be configured to about 19.28:1. I know that there are some 2 speed gearboxes with that large of a reduction, but I would prefer not to spend twice as much money for a shifter with an unusable top speed.
My team is planning on using 8 inch wheels so the large reduction is necessary to get to a goal speed of roughly 7 fps.
Unread 12-01-2016, 15:47
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Large Reduction Single Speed Gearbox
Also because of large wheels, we're not using our gearbox for direct drive, but using chains with different sized sprockets for additional reduction.
Unread 12-01-2016, 16:21
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Team Role: Coach
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
The only gearbox we've found that will allow you to direct drive an 8" wheel at a reasonable speed is the West Coast Products Single Speed gearbox. I'm fearful for rookie teams that attempt to direct drive their KOP frame using 8" wheels using the Toughbox Mini's, it'll be hard to control at such a high speed on such a sectioned field.
Just wanted to add that I'm really impressed by the flexibility the WCP SS gearbox gives. 4 different pinion choices allowing you to basically go up or down ~1 ft/s at a time. We could go 7.5 ft/s or 10 ft/s by swapping pinion gears, love it!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 12-01-2016, 16:23
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
If you can't find a COTS gearbox, try adding another stage of reduction in the sprocketing.
Also, is there any reason why you chose 7 fps as your ideal speed? Why not a bit faster?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 12-01-2016, 16:35
InFlight's Avatar
InFlight InFlight is online now
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
Your target single speed of 7 ft/sec is much lower than is normally used, and with large 8 tires, it pushes it out the required gear ratio to 22.2:1. There are no COTS double reduction gearboxes with that type of ratio.
There are the COTS IR3 Modulux gearbox that you could customize (expensive).
It you had the ability to manufacture a triple reduction gearbox
A (50/12) (60/24) (64/30) = 22.2
12 tooth CIM
Stacked 50 & 24 (CIM drives 50)
Stacked 60 & 30
64 on Output Shaft would do the trick
Spacing is 1.55" CIM Center to First Shaft
2.10" First to Second Shaft
2.35" Second Shaft to Output Shaft
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 12-01-2016, 16:43
ASD20's Avatar
AKA: Andrew
Rookie Year: 2014
7 fps is just an rough initial estimate. Through initial testing my team has discovered that with too fast a speed (we tested with 14 fps), a robot will either struggle over some of the obstacles (we specifically cheval de frise and ramparts) or will go flying. We are looking for a lower speed that will offer more control. However, we may decide that 7 is too slow and go up to 9 or so.
Unread 12-01-2016, 16:56
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
QFT most of the AndyMark Toughboxes are 12.75:1 stock.
2:1 can be obtained and that's more than you ask for.
Unread 12-01-2016, 16:58
InspectorGadget1073's Avatar
InspectorGadget1073 InspectorGadget1073 is offline
Jedi Master
FRC #1073 (The Force Team)
Rookie Year: 2014
InspectorGadget1073 is an unknown quantity at this point
Our team is only using 6 inch wheels. Please help us all.
"I'm a human entropy producer." ~Dean Kamen, Our Lord and Savior
Unread 12-01-2016, 17:11
ASD20's Avatar
AKA: Andrew
Rookie Year: 2014
Now that I think about it, it is kind of interesting that Andymark is selling a kit where the slowest possible configuration is 14 fps and not warning people. I can see there being a lot of surprised rookies who cannot control their robot.
Unread 12-01-2016, 17:32
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Oh, you don't remember the 2011 kitbot that was geared out of the box for 18 fps? Man those were the days...
Unread 12-01-2016, 19:19
techhelpbb's Avatar
Rookie Year: 1997
What sort of help do you need?
Are you trying to target a certain number of feet per second?
or
Are you trying to target a certain ratio?
Resources on ChiefDelphi that can help you:
JVN:
http://www.chiefdelphi.com/media/papers/2059
Thad house:
http://www.chiefdelphi.com/media/papers/2681
Chris L:
http://www.chiefdelphi.com/media/papers/2165
As pointed out before if you can't get a ratio high enough from an existing gear box use that gear box to drive a belt or chain sprocket and then select those pulleys/sprockets to multiply the ratio.
For example: If a AndyMark ToughBox has a default ratio of 12.75:1 and drives a double 1/2" bore #35 sprocket with 12 teeth. Then drive the wheels with a 24 tooth sprocket (which happens to even fit a 4" AndyMark wheel) you have an additional 2:1 so that's total a 25.5:1 gear ratio at the wheel hubs. If you used the 15 tooth double #35 sprocket that chain will be a ratio of 1.6:1 so total that's 20.4 at the wheel hubs. If you play around with alternate gears within the ToughBox you can take that further. It's easy to get an additional 3:1 in just sprockets and chain using a 12 tooth #35 to a 36 tooth #35 sprocket especially if your tires are larger than 4" to add clearance for the chains (so with 12.75:1 and 3:1 that would be a total ratio at the wheel hubs of 38.25:1 and that's not even the maximum).
Make sure to consider the losses in the system that's why I linked the various common calculators.
I see AndyMark clearanced out all the StackerBoxes. I bought a bunch. They can feed into each other to multiply over and over the gear ratio just by assembly. Too bad they had 3/8" shafts. Each StackerBox had a 14 tooth and 50 tooth gear stock. So you could easily stack 3 and get a ratio over 45:1.
