Go to Post The FIRST family is incredible. - Libby Ritchie [more]
Unread 12-01-2016, 15:18
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Drawbridge Door Contact Question
I know for a crossing of the Drawbridge to officially count, a robot in the neutral zone not touching any component of the outer works must cross completely through the obstacle into the Courtyard. Also, it's legal to use teamwork to hold the drawbridge door down for another robot to cross through.
Can anyone say for sure if the following maneuver is regarded as a Drawbridge crossing (before I ask in the GDC):
Cross a different obstacle into the opponent courtyard, drive through the Drawbridge from the back (driving back into the neutral zone, but using an extrusion to hold the door open), then "tapping" the Drawbridge door into the ground (which will instantaneously lose contact with the arm and entire robot), then simply driving back through the Drawbridge obstacle to claim an entry?
I don't see a rule stating that the drawbridge door must be fully closed or a certain amount of time must pass between obstacle contact to declare it to be the start of a Crossing.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 12-01-2016, 15:27
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: Drawbridge Door Contact Question
so far, so good
Make sure you comply with "completely in the Neutral Zone", so the part your "tap" needs to be the portion of the door in the neutral zone.
IMHO: If you are going to employ that strategy, then you better warn the Refs in advance so that they will look for it.
Unread 12-01-2016, 15:44
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
Rookie Year: 2014
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
I was also planning on asking a Q and A question about how long you need to not be in contact with the defenses for.
Disclaimer: All references to rules and legality are from current or past seasons and it should not be assumed that any rule will remain the same in future seasons.
Unread 12-01-2016, 15:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
We're thinking about trying this as a self-drawbridge/sally port crossing. I think better than tapping is having your extension out to catch the drawbridge. Drive off it, drawbridge swings up, catch with the extension and push it down to drive back. It's probably a little slower, but it's a lot more obvious you're not touching the drawbridge if it's free-swinging upwards.
But yes, you'll definitely need to warn the refs for the first few matches. Though if this is legal, I think it'll be common enough that they'll just watch for it rountinely.
Unread 12-01-2016, 16:24
Tom Bottiglieri Tom Bottiglieri is offline
Custom User Title
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Send a message via AIM to Tom Bottiglieri
This seems hacky. I'd amend the rule/blue box to look something like this:
When a ROBOT passes from their opponent's COURTYARD to the NEUTRAL ZONE through a defense in GROUP C, the spring assisted door must either return to its original position or have its motion impeded by an ROBOT of the same ALLIANCE
Team 254 | San Jose, CA | Mentor (2010 - Present)
Team 125 | Boston, MA | College Student (2007 - 2011)
Team 195 | Southington, CT | Student (2002 - 2006)
Unread 12-01-2016, 16:36
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud ofnuclearnerd has much to be proud of
I agree. This would turn the Category C defenses from the hardest to the easiest obstacles - changing the flow of the game completely from the GDC intent (I imagine). That said, I'll be watching the QA closely about this.
Unread 12-01-2016, 16:45
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Tom's proposal doesn't "turn" anything, it's currently the rules as written (aside from the "tapping" the OP is proposing).
Unread 12-01-2016, 16:49
InspectorGadget1073's Avatar
InspectorGadget1073 InspectorGadget1073 is offline
Jedi Master
FRC #1073 (The Force Team)
Rookie Year: 2014
InspectorGadget1073 is an unknown quantity at this point
Just a warning--It may be really hard to become entirely in the neutral zone (You cannot be in the volume above the ramp), so please be weary before employing this strategy.
"I'm a human entropy producer." ~Dean Kamen, Our Lord and Savior
Unread 12-01-2016, 16:57
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Not sure I read the rules that way. Do you have a reference for that? Here is the definition of the OUTER WORKS
an infinitely tall volume bordered by the GUARDRAIL, the SECRET PASSAGE, and 2 in. white gaffers tape (The OUTER WORKS includes the white gaffers tape, but does not include the GUARDRAIL or SECRET PASSAGE). It consists of a series of five (5) DEFENSES, five (5) PLATFORMS, and five (5) Shields arranged in a line across the FIELD and is designed to impeded the passage of ROBOTS and BOULDERS in to the COURTyARDS
Nothing about that indicates that the open ramp is included in the volume of the OUTER WORKS. Therefore, that space should be in the NEUTRAL ZONE.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2016: Greater DC, Central MD, Chesapeake District Championships, Championships
Unread 12-01-2016, 17:10
dieDoktor dieDoktor is offline
AKA: Kipling Cohen
FRC #4118 (Roaring Riptides)
Team Role: Mechanical
Rookie Year: 2011
dieDoktor is an unknown quantity at this point
Where does it say this? The manual says that:
A DEFENSE is CROSSED by a ROBOT when that ROBOT
■ starts free of contact with the DEFENSE and completely in the NEUTRAL ZONE
Since the Drawbridge door extends down into the NEUTRAL ZONE, once you are clear of contact, you're good to cross.
Unread 12-01-2016, 21:20
Jedi Master
Rookie Year: 2014
I interpreted this since that the OUTER WORKS is infinitely tall zone and the robot cannot be in this zone and completely in the NEUTRAL ZONE at the same time. I assume that the ramps are part of the OUTER WORKS also.
Unread 12-01-2016, 21:26
Rookie Year: 1998
Originally Posted by Section 2.2.2
The OUTER WORKS is an infinitely tall volume bordered by, but not including, the GUARDRAIL, the SECRET PASSAGE, the COURTYARD and the NEUTRAL ZONE.
So no.
Unread 12-01-2016, 21:55
wjd13 wjd13 is offline
FRC #4905 (Andromeda One)
Rookie Year: 2015
wjd13 is an unknown quantity at this point
So I was thinking of something similar, along the lines of driving off of the drawbridge, letting it spring up, and then catching it with some sort of arm mechanism. I think you should definitely let the referees know about your strategy beforehand, but from my reading of the rules it seems legal.(by the reasons mentioned earlier in this post)
It should also be pretty easy for your robot to be in the neutral zone, since the drawbridge is 37" long, and thus would extend ~25" into the neutral zone when fully down (-12" for the 12" ramp). And since you can't have your arm extending >15" out from your frame/bumpers, that means that when you employ this strategy you should always be ~10" from the outerworks at the very least. One thought is that perhaps you could sit on the door just a second before doing your tapping/ catching of the door on the way up, just so the refs have a chance to catch it.
Unread 12-01-2016, 16:59
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
Heh. OK, but I smell an unintended consequence of a poorly written rule. I wager they'll change it (but we will happily play the door tapping game if not).
  #15   Spotlight this post!
Unread 12-01-2016, 17:02
AKA: Josh P.
Rookie Year: 2007
Sorry, I misinterpreted, I though "this" in your post meant Tom's interpretation/the-current-rulebook-besides-tapping, implying being able to "follow each other through" the doors would be game breaking. I also think tapping is silly.
