Go to Post What if, each alliance has a pile of AndyMark equipment in front of them. They then have 2:00 minutes to assemble said equipment, and build a working robot that will race to the other side and grab the other alliance's flag. - Pjohn1959 [more]
Unread 12-01-2016, 15:18
JMSRobots JMSRobots is offline
FTC #6431
JMSRobots is an unknown quantity at this point
FTC Core Device Interface Not Showing Up
Hello All!
Our team has been experiencing some difficulties detecting the Modern Robotics Core Device Interface Module. If it helps, we are using a hybrid of parts from the old NXT setup and parts from the new Android setup. Here are the steps we followed to detect the Core Device Interface Module.
  1. Open FTC Robot Controller App
  2. Open the Menu
  3. Tap Settings
  4. Tap Configure Robot
  5. Then tap New
  6. Then tap Scan
Below is an image showing what appears when we Scan for Devices.
Below is an image showing our robot. Take note that the Core Device Interface is receiving power.
Many Thanks,
JMSRobotics
Unread 01-03-2016, 09:33
afilini afilini is offline
afilini is an unknown quantity at this point
Re: FTC Core Device Interface Not Showing Up
Hi,
we are having the same issue here, we just updated the SDK. Have you been able to resolve the problem?
