Defenses and Breaching
Me and my coach have had an ongoing debate on whether you can fully damage a defense by yourself.
i.e. I go through the low bar twice and reducing it's health to 0 points, scoring five points both times Is this possible. |
Re: Defenses and Breaching
Yes but as the rules states you have to go from the neutral zone to the enemy courtyard to weaken a defense.
In teleop, You can breach all the defenses you want |
You cannot damage a defense unless you start completely in the neutral zone, and cross all the way into the courtyard, but there is no rule saying you cannot then back up across the defense and cross it again
I'm slightly confused as to what "Once a ROBOT CROSSES a DEFENSE in AUTO, any additional DEFENSES that ROBOT
REACHES or CROSSES during the AUTO period will not decrease DEFENSE STRENGTH nor contribute points to the ALLIANCE." means. Does that mean you can CROSS the same DEFENSE twice and decrease its STRENGTH and score twice? The use of the word "additional" just hit me funny. |
Let me try to explain with examples.
1. get through a defense and be totally in the courtyard. Score 10pts for crossing, defense takes a point of damage. 2. Get through a defense in to the courtyard (defense takes 1pt of damage), turn around drive over a defense in to the neutral zone. Turn around, drive over the defense and in to the courtyard a second time (defense does not take any damage and you get no points). 10pts Brian |
In Autonomous- no you cannot totally damage a defense on your own because you can only get points for crossing one time.
In Teleop- YES, ABSOLUTELY. You can damage any or all the defenses, getting points for crossing both times. |
What if 2 robots from the alliance cross the same defense? For example, they take turns crossing the low bar.
3.1.3 says "any additional defenses that robot crosses", which suggests that 2 robots crossing the same defense would count as damaging. Would take good cooperation to get timing right, though, with little benefit unless both 'bots were only able to cross low bar. |
#10
As to scoring for crossing defenses, does everyone agree that you can only score points for crossing a defense twice with a maximum of 50 points possible for all 5 defenses? After damaging a defense there are 0 points for crossing any more?
#11
That is to say, it does not imply that a DAMAGED defense no longer awards points for additional CROSSINGS. This will be one for the Q&A for sure. |
#14
Nope look at the scoring chart on 3.3.1. Points are awarded for CROSSING an UNDAMAGED DEFENSE. Once it has been CROSSED twice it is DAMAGED.
#15
Ahah! There it is, good catch
