Go to Post Whenever we loose a committed member of FRC, our entire country pays the price. - daniel_dsouza [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-01-2016, 22:29
jtcoyle jtcoyle is offline
FRC #6217
jtcoyle is an unknown quantity at this point
Drive Base Kit missing Hex spacers? Or, don't understand build instructions.
We're a rookie team just trying to build the base drive chassis from the instructions provided. Have other designs working, but wanting to get started quickly. Based on instructions, the 0.570 in hex spacer should only go on the outside of the two center drive wheel shafts. Therefore, only two provided in the kit. After putting it together, the center wheel are very loose. Seems to be because no spacer on the inner side shaft. If both spacers are used on one wheel, that wheel is solid.
Am I doing something wrong? Or, do I need to order two more hex spacers?
Unread 12-01-2016, 22:37
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Re: Drive Base Kit missing Hex spacers? Or, don't understand build instructions.
The center wheels should have an aluminum hex hub screwed into one side of the wheel and the hex spacer pressed into the center of the other side of the wheel. The aluminum hub is what actually transfers torque from the shaft to the wheel; the spacer is just there on the other side to keep the wheel aligned.
See step 5 of the Center Wheel Assembly Instricutions on Page 8 here: http://files.andymark.com/PDFs/AM14U3_UserGuide_1.1.pdf
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 12-01-2016, 23:06
FRC #6217
That makes sense. I will try it tomorrow. Thanks for the quick reply.
