Go to Post I implore you to not spend your mental energy on preparing your argument for the inspectors. We all have better things to be thinking about and working on. - mrnoble [more]
  #16   Spotlight this post!
Unread 13-01-2016, 01:39
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Versa gear box
Ok so I just watched the vid with sound... So mini cims, but was said in vid that it was with versa plan at 1:1. I am wondering how you did that? Isn't the lowest reduction 3:1 in the versa? We have designed a very similar shooter. Have to test it and a linear puncher
  #17   Spotlight this post!
Unread 13-01-2016, 01:52
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Re: Versa gear box
You are right. The lowest gear stage you can get is 3:1. However it is possible to put a Versa Planetary togeather without a gear stage. That is when you get a 1:1.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
  #18   Spotlight this post!
Unread 13-01-2016, 02:32
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Rookie Year: 2014
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: Versa gear box
Now that the thread has been hijacked..... Anyone have an idea on the force to back drive with a 20" bar on it?
I think backdrive is about torque, not force, so it would depend on where on the arm the load would be applied.
At that point, it would act more like a shaft adapter than a planetary gearbox.
  #19   Spotlight this post!
Unread 13-01-2016, 03:18
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: Versa gear box
You have to get creative during Ri3D There is no such thing as ordering that one specialty component that you need, and it's financially impossible to plan for everything. We also wanted to put them in the versa planetaries for the adjustability in case we weren't satisfied with 1:1.
Just to be clear, running 4 inch wheels at a 1:1 ratio from a mini cim controlled down to 50% speed will stall. It needs to have that built up speed for it to intake. The great thing is, that ridiculous speed doesn't cause the wheels to slip on the boulder. If you touch it, you own it, and it makes a seriously cool sound when you intake.
  #20   Spotlight this post!
Unread 13-01-2016, 03:21
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Re: Versa gear box
From our tests a linear punch wasn't a highly desirable option for us anyways because it lacks a long range. The boulders absorb a lot of that impact. For your wheeled shooter, I recommend using a servo with a lever attachment to kick the ball into you wheels. It has a small profile, and doesn't require you to add pneumatics.
  #21   Spotlight this post!
Unread 13-01-2016, 06:56
dradel's Avatar
Rookie Year: 2013
How do you run a versa at 1:1? I'm confused. We have yet to use the versa boxes . Going to be a bunch of first time uses on this years robot for us.
  #22   Spotlight this post!
Unread 13-01-2016, 10:49
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
Re: Versa gear box
Originally Posted by Charding18 View Post
So basically it would be unwise to use the 100:1 versa gearbox to use as a winch to climb? Is it not strong enough to lift the robot or does it just have a lot of slippage?
Our FTC teams chose 100:1 VP gearboxes for their Res-Q hangers, two per robot (as has been suggested earlier in this thread.)
Before they added a secondary clip to the robot to hold it in place once it reached max height, their robot slid back quite a bit, and they don't weigh nearly as much as FRC.
You might be able to get up there, but you'll want other mechanisms making sure you have a secure hold.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
