Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 13-01-2016, 00:41
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Permitted Ethernet hubs / switches
With the roboRio and the new radio, our team will likely want additional Ethernet ports on the robot.
I'm trying to find the rules that say what may or may not be permitted along the lines of an Ethernet hub / switch.
Can someone please refer me to the rules that guide this, or suggest permitted switches / hubs?
Thanks,
Martin Haeberli
Mentor,
FRC 3045, Gear Gremlins
Unread 13-01-2016, 01:05
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: Permitted Ethernet hubs / switches
Any 5v or 12v non-broadcasting switch/hub should be fine.
"R59 Ethernet-connected COTS devices ..."
Unread 13-01-2016, 10:24
FRC #3045
Thanks!
Unread 18-01-2016, 14:57
buckskinner1776 buckskinner1776 is offline
FRC #3098
buckskinner1776 is an unknown quantity at this point
We are also looking at the same thing for multiple cameras and laptops while in pits. Any suggestions on an inexpensive five port switch? Preferably 12v.
Unread 18-01-2016, 15:18
Rookie Year: 2012
The D-Link from last year is free. Make sure you turn off the wifi, and LABEL the power connection (so you don't mix up the routers and burn up the D-Link).
5 volts
http://www.newegg.com/Product/Produc...-112-_-Product
http://www.newegg.com/Product/Produc...-066-_-Product
I think this one is 5 volts
http://www.newegg.com/Product/Produc...-026-_-Product
Unread 18-01-2016, 15:20
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
My go to 5 port switch is the Netgear one. It comes in a metal case and will manage an accidental smack in the pits.
For the robot you could use this 5 port switch that works on 5 volts. It's in a plastic case and is much lighter than the Netgear one.
Note, both are 10/100 switches, but it's unlikely you'll need gigabit speeds on the robot or in the pits.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
