Go to Post I could say something technical but I think I will allow myself a moment to pause in the awesomeness... Sweet. - anna~marie [more]
Unread 13-01-2016, 09:42
Taggerun's Avatar
Taggerun Taggerun is offline
The Lone Programmer
FRC #3036 (DROBA Warriors)
Rookie Year: 2016
Taggerun is an unknown quantity at this point
Exclamation Labview Teleop.vi Issues
On the Second Build Day the programmers on team 3036 wanted to have the robot driving. Well everything was wired up correctly but only one side of the robot was moving (we use tank drive). We tested all the joysticks and they are working. We looked at the 2014 Labview only to find big differences between the two. What should we do?
P.S. I will include pictures of the program if necessary, just say that I need to include pictures.
Thanks,
Taggerun in behalf of team 3036
"Think Outside The Bot.…"
Unread 13-01-2016, 10:20
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Labview Teleop.vi Issues
Are you testing with the default project, no modifications?
What are the status lights doing on the motor controllers?
What kind of game controllers are you using?
What USB position are they in on the Driver Station USB tab?
Unread 13-01-2016, 14:51
Taggerun's Avatar
The Lone Programmer
Rookie Year: 2016
Exclamation Re: Labview Teleop.vi Issues
How do you program a Jaguar and a Victor 888 together in Labview??
Thanks,
Taggerun
"Think Outside The Bot…"
Unread 13-01-2016, 15:50
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Thanks,
Taggerun
The Open VI for the motors gives you that option. If it's for the drive, I would recommend you use the same motor controller for all 4 motors. It'll keep the motors working equally as hard.
If you must, you can always open the 4 motors without using robot drive. There is nothing keeping you from running the motors in a more 'manual' approach.
It might help for you to be more descriptive. I'm not good at reading minds.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 13-01-2016, 16:28
You can also build a robot drive where you wire up four already-opened motor references. At that point, you are not getting much benefit from the RobotDrive, but it is an option.
Greg McKaskle
Unread 14-01-2016, 08:11
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
This problem could be in either software or hardware. If the problem still persists, please post some pictures of the wiring and the code, specifically power and pwm/can connections and begin.vi and teleop.vi.
