Go to Post My crotchety old person opinion is that it should be illegal to try to win the award. Do things because you like doing them or because it helps others. Don't do things to win awards. - Madison [more]
Unread 13-01-2016, 10:45
rsaccone rsaccone is offline
FRC #3950
rsaccone is an unknown quantity at this point
C++ Install Issue - Compilers not found...
Hello,
I've done a clean install of the build environment setup for C++ on Windows using the screen steps. When I attempt to generate a sample robot project I two things occur that aren't right.
First I never get the prompt asking me to enter my team number.
The second is I get a number of build errors complaining about the C++ compilers not being found, see below. Prior to installing Eclipse I downloaded and installed the FRC-2016 Windows Toolchain 4.9.3.msi. I then installed Eclipse and installed the plugins using the online site. Everything installed without any errors. I figure I must have missed a step somewhere. Can someone point out what I have done wrong here?
Thanks,
Rob
Description Resource Path Location Type
Program "arm-frc-linux-gnueabi-g++" not found in PATH Getting Started Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "arm-frc-linux-gnueabi-g++" not found in PATH Test Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "arm-frc-linux-gnueabi-gcc" not found in PATH Getting Started Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "arm-frc-linux-gnueabi-gcc" not found in PATH Test Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl" not found in PATH Getting Started Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl" not found in PATH Test Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "g++" not found in PATH Preferences, C++/Build/Settings/Discovery, [CDT GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "gcc" not found in PATH Preferences, C++/Build/Settings/Discovery, [CDT GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "gcc" not found in PATH Getting Started Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Program "gcc" not found in PATH Test Project Properties, C++ Preprocessor Include.../Providers, [CDT Cross GCC Built-in Compiler Settings] options C/C++ Scanner Discovery Problem
Unread 13-01-2016, 11:29
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: C++ Install Issue - Compilers not found...
If you didn't delete the USERS\wpilib folder your team number setting persisted from the previous install.
Assumed that the errors are a problem. Can you build a program?
Unread 13-01-2016, 11:57
FRC #3950
No I can't build the sample Robot project that I generated from the project wizard. I get the errors complaining about g++ and gcc not found on the path. Twice now I have deleted eclipse and uninstalled the toolchain msi and reinstalled but I've gotten no where.
Unread 14-01-2016, 22:54
RaskorTheWise RaskorTheWise is offline
AKA: Noah Gersh
FRC #2551 (Penguin Empire)
Rookie Year: 2015
RaskorTheWise is an unknown quantity at this point
Having the same exact issues. Running Windows 10, if that would make a difference.
Unread 15-01-2016, 08:58
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
g++ and gcc not found on the path are not actual errors. Your code should still build and deploy just fine. If you want to remove the errors, the easiest way is to install some gcc (like MinGW) and put it on your path. We use the arm-frc-linux-gnueabi- prefixed compilers, but eclipse likes to have vanilla gcc available as well.
Unread 17-01-2016, 00:48
vettenoir's Avatar
vettenoir vettenoir is offline
AKA: Bob Hedrick
FRC #5885 (WiredCats)
Rookie Year: 2016
vettenoir is an unknown quantity at this point
Where is the toolchain supposed to install? I never got prompted for a location for the software and it installed to backup drive attached to a USB port on my system (I:\frc).
I moved the frc folder to where I wanted it, edited the project properties to match, and the error messages disappeared. I am running Windows 10.
FWIW,
Bob
Unread 17-01-2016, 01:16
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
FWIW,
Bob
The installer installs on the drive you run it from. This means that you need to run it from the same drive that eclipse is installed on. That might be @rsaccone's issue.
Also, double check that [eclipse drive]:\frc is on your PATH environment variable.
Unread 17-01-2016, 12:49
vettenoir's Avatar
AKA: Bob Hedrick
Rookie Year: 2016
I never had the msi file on my backup drive on which it installed. There must be something else in the installation script. I did do multiple installs and uninstalls initially, when I couldn't figure where the software had installed. That may have affected its action.
Good advice. This is what solved the issue for me and would probably solve the issue for @rsaccone
Thanks,
Bob
