Go to Post The spirit of FIRST lives in all of them[us]. Knowledge is power and the unknown is scarey but in the end the spirit of FIRST will endure. - LSevcik [more]
Unread 13-01-2016, 11:49
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
New Camera in Budget, What model and why
So we have in our budget this year to buy a new camera (we have been using an Axis 206 forever and want to upgrade to a Axis M1011 or M1013 ( we tried the Microsoft HD camera last year and had a fit of problems then went back to the 206).
we use Java for programming and are planning on using RoboRealms.
lets say that sourcing and price isn't a problem.
What version of Axis camera would you go with, and why?
What are your experiences with these cameras?
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 13-01-2016, 13:37
AlexanderTheOK AlexanderTheOK is offline
Guy
Rookie Year: 2012
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Re: New Camera in Budget, What model and why
The only real differences between the two is the viewing angle (67 degrees for the m1013 vs 47 degrees for the m1011.) and the m1013 has adjustable focus. There's no real "competitive" advantage to either. (Maybe teams might actually want a smaller viewing angle to get the targets better in their sights?)
Unread 13-01-2016, 13:56
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
So you want to stick with IP connected cameras not USB cameras right?
I assume the Microsoft HD camera you tried was USB?
Have you considered Logitech cameras for USB?
Are you hoping for high resolution and field of view for fixed targets
or
Tracking of moving targets which really needs frames per second?
There are plenty of USB2 1080P webcams out there if you want resolution and are not planning on pumping that over the 7MB/s to the driver's station. Once you decide to pump video back to the driver's station you'll be limited in resolution and frame rate. There are multiple ways to reduce the resolution of the video you send back to the driver's station if you can process that video on the robot before it gets there.
Unread 13-01-2016, 16:02
Stuart's Avatar
#include coffee.h
the issue we had last year with the USB camera ( Microsoft HD 3000) were with capture speed. 1 FPS was as good as we were able to get(even at very low resolutions), comments, threads, and testing on the CD Java forums indicated this was an issue with the java library and (not the 7MB/s limit to the driver station) for non IP cameras.
I have for my personal use a HP webcam so we might test that at some point but I would rather go with something I know I can get results. Using vision to score goals in autonomous Inspires students, boxing webcam firmware drivers and Java libraries to get a halfway decent view of what the robot is kinda looking at , not so much.
I'm mainly asking if there are any big advantages or pitfalls with the Axis versions. or is it just the one has a slightly larger viewing angle? if this is the case I will just leave it up to the students as to what they think is better (sounds like a fun exercise)
Last edited by Stuart : 13-01-2016 at 16:07. Reason: clarity, adding additional answers
Unread 13-01-2016, 16:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Our webcam ran at about 24 fps without an issue last year.
However, I'll warn you that the contrast adjustment on the 1011 and 1013 are not nearly as good as the older 206. In the past, you could hold a white sheet up in front of the camera and get it to hold the contrast so low that everything would appear dark except the really lit-up areas. The 1011 and 1013 will hold this until you repower the camera, then they reassert some low-default value. If you want the same effect on the newer cameras you'll have to put some type of filter (like a sunglass lens) over the front of it.
Unread 14-01-2016, 16:38
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
What issues were you having with the MS USB?
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 16-01-2016, 07:50
Stuart's Avatar
#include coffee.h
Hey everyone thanks for the replys. we feel that we have a better idea of the choice we have and can now make an informed decision.
Unread 16-01-2016, 08:31
Jonathan L. Jonathan L. is online now
FRC #1094
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
I think you are talking about the exposure, not the contrast right? I beleive both the M1011 and the M1013 cameras have a setting that changes the exposure to "Hold Current" which works over power cycles. However the M1013 will still adjust the exposure slitly over time. For using vision, I recommend the M1011. I would also recommend removing the code from the robot that sets the camera settings, and only use the settings on the camera's webpage.
Unread 16-01-2016, 10:50
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
Rookie Year: 2013
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
On a side note, how will you get the axis camera to fit in the new radio with only 2 ethernet ports? If only there was one more...
Head Programmer / Driver
Unread 16-01-2016, 11:57
Tom Line's Avatar
Rookie Year: 1999
You could always add a network switch to the robot.
