Go to Post Enjoy doing what you do. If you enjoy your life, what you're doing in it, and how you're living it, then what other people say or think doesn't matter. - Beth Sweet [more]
Unread 13-01-2016, 13:32
Pearl3946 Pearl3946 is offline
2015 Drive Coach and Captain
FRC #3946 (Tiger Robotics 3946)
Team Role: RoboCoach
Rookie Year: 2014
Pearl3946 is an unknown quantity at this point
The Sally Door
The Sally Door might just be the one thing that ends my sanity! I've been racking my brain, Google, and YouTube to find a time efficient way to open the Sally Door without opening from the others side. How are ya'll tackling this defense, if even at all?
Unread 13-01-2016, 13:36
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
Re: The Sally Door
here's an idea
Hi!
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
Re: The Sally Door
Originally Posted by Pearl3946 View Post
Sally Door
Yes, Sally Door.
The Ri3D 1.0 team has a device on their robot that can open the Sally Port. You can check it out in their reveal video: https://www.youtube.com/watch?v=Kd1FaSNoDiM
Unread 13-01-2016, 13:43
Rookie Year: 2014
Re: The Sally Door
thank you! my team has watched that video and it was a great way to get ideas flowing. We like the concept of the function, but we are also looking for a way so that we don't have to spend time working our way around the door before going through the defense. The problem is the fluid motion of it all.
Unread 13-01-2016, 13:50
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: The Sally Door
Opening the Sally Door and being able to go under the low bar will be an interesting challenge. I think the most efficient way will be to design an alliance game flow that uses a partner to open it for you.
Unread 13-01-2016, 13:53
Rookie Year: 2014
Re: The Sally Door
If breaking the defenses is one of our main functions do you think we'll still be valuable as an alliance partner if all we can do is open and hold the sally door open for others?
Unread 13-01-2016, 13:56
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
Rookie Year: 2007
cj3958 will become famous soon enough
Re: The Sally Door
WARNING!!! The sally door and the drawbridge are made out of very flexible material(slightly stiffer than 1/32-1/16th polycarb), opening them the way Ri3D did will almost certainly not work. DO NOT make those barriers out of plywood because that is nothing like what it will be on the field.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
Unread 13-01-2016, 13:58
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: The Sally Door
Assuming you're still able to breach the other defenses, and assist in capturing the tower, it wouldn't be a bad strategy to approach.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
Rookie Year: 2007
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
Re: The Sally Door
If opening the sally port is tricky, hold it open for an alliance partner and then following them through would be ideal. You only have to manipulate it once to damage it.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 13-01-2016, 13:59
John Retkowski's Avatar
John Retkowski John Retkowski is offline
Team 316 alumni
AKA: Wyatt. Call me Wyatt.
FRC #0316 (LuNaTeCs)
Rookie Year: 2012
John Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of light
Re: The Sally Door
It would definitely be a viable strategy, but you have to consider what your robot will do in matches when A.) the sally port isn't chosen as a defense, and B.) after the sally port defense has been damaged.
Your robot could also choose to defend your tower in either of these situations.
2015 MAR District Championship #1 seed Winners (w 225 & 203)
2015 Upper Darby District #2 Seed Finalist(w 272 & 5420)
2015 NE Pioneer Valley District #3 Seed Finalists (w 61 & 663)
2014 Lenape Seneca District Champions (w 3929 & 2559)
2014 Springside Chestnut Hill District Champions (w 225 & 1495)
2013 Lenape Seneca District Champions
2013 Springside Chestnut Hill Finalists
Unread 13-01-2016, 14:08
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Re: The Sally Door
When you break a defense you have to get back to the neutral zone somehow. It only makes sense to break a defense on your own, get back to the neutral zone through the [insert gated defense] and allow a partner to go through. Then after they are on the gate, holding it down, you'd just have to fully get into the neutral zone and then follow them through.
A robot dedicated to doing nothing but breaching/smoothing the flow of an alliance should be incredibly valuable at a regional/district level. At Champs these robots should also be able to contribute in other ways.
Unread 13-01-2016, 14:16
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
Rookie Year: 2011
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Re: The Sally Door
Actually both the Sally Port door and Drawbridge gate are made of two pieces of .125" polycarb sandwiched together for a total thickness of .25 inches. As noted in several threads (info from the 2016 Field Component drawings).
Alan Gilgenbach
C.O.R.E 2062
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Rookie Year: 2011
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
Re: The Sally Door
Why do you think that opening them this way will not work? Are they too flexible and will just bend?
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 13-01-2016, 15:23
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: The Sally Door
Not to be too picky but its a Sally Port and not a Sally Door... not to be confused with a Sally Ride, or a Sally Field or a Sally Hemings or even a Sally Jesse Raphael
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
