Go to Post They're just dots. You can get them back. - Brandon Martus [more]
Unread 13-01-2016, 14:03
Shaif Shaif is offline
FRC #5580 (SQUAD)
Rookie Year: 2015
Shaif is an unknown quantity at this point
Good place to buy pneumatic wheels in Canada?
We're trying to avoid Andy Mark because of the crazy amount of extra money we would have to pay ($ is poopy and shipping).
Do any of you have any good places to order our know good stores to go to for 8 inch pneumatic wheels?
Unread 13-01-2016, 14:07
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Good place to buy pneumatic wheels in Canada?
you can get the wheel fairly easily, Home depot probably has them. It's the hub you would have to source, unless your ok with the heavier hubs.
Unread 13-01-2016, 14:09
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
This maybe?
http://www.harborfreight.com/8-inch-...ire-47638.html
Unread 13-01-2016, 16:38
nollchr nollchr is online now
Rookie Year: 2014
nollchr is an unknown quantity at this point
Quite an assortment of 200 mm x 50 mm pneumatic tires on Amazon too. As others have mentioned, the hub portion seems to be an Andy Mark item if you want the compatibility with the chassis kit. The 8" pneumatic wheel also seems popular for powered scooters so I found some medical scooter part online as well. Can speak for the Canadian factor but Home Depot and Harbor Freight have some options as well. Some are mount on castors but you might be able to salvage the wheels from them.
Unread 14-01-2016, 08:37
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is an unknown quantity at this point
We're looking at maybe 3D printing our hubs using PLA and the higher, 90% infill rate. How do you think they'd hold up?
Unread 14-01-2016, 08:44
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Originally Posted by BitTwiddler View Post
that makes half your robot's weight if you have a 6 WD
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 14-01-2016, 15:02
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
8" is a bit small compared to what the hardware stores around here tend to stock. You'll have an easier time finding 10"+, but that limits your wheel configuration to 4wd, or a really narrow 6wd, and both of those come with their own set of problems. Apart from home depot, princess auto also carries a selection of tires. if the right size is not available locally you can order from Mcmaster-Carr, they are in the US but shipping is really reasonable and fast. They carry a huge selection of tires, it's not cheaper, but it's always going to be in stock.
http://www.mcmaster.com/#pneumatic-tires/=10ojbe7
Although the Andymark wheels are expensive to get to us, and are not in stock atm, the fact that the hubs use the FRC standard bolt pattern means they can easily be attached to the belts and sprockets that vex and andymark have available. Converting other pneumatic wheels requires you to do one of following:
Make the standard 6 hole bolt pattern on the hub (which may already have a 4 bolt pattern on it)
or
modifying your sprockets/chains/gears to fit the existing pattern on the hub
Both options work, but if you do choose to do this know that it does take some time to fabricate. Care needs to be taken to keep them as concentric as possible unless you don't mind a lumpy robot, definitely something that should be done on a mill if possible.
2005-2006,2011 FRC 865 Warp7 Student, Mechanical team
2013 FRC 1310 RUNNYMEDE ROBOTICS Mentor, CAD and Manufacturing
2014-2015 FRC 5031 Downsview Robotics Mentor, Design and Manufacturing
2016-Present FRC 1360 Orbit Community Robotics Mentor, Design and Manufacturing
Unread 14-01-2016, 15:05
FRC #1360
Princess Auto in Mississauga has a sale on 8 inch pneumatic tires if your interested
Unread 14-01-2016, 17:08
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Beat me to it... Princess Auto has some good deals. http://www.princessauto.com/en/detai...el/A-p8039976e
You might also find dealers such as http://www.castertown.com/ who can help you out. (Look under "Hospital Equipment")
This also reminds me that I'd heard that at Sunnyhill Children's Hospital in Vancouver there is apparently a basement room filled with broken electric scooters and wheelchairs. If you find an electric wheelchair/scooter repair house, then you might find some really nice wheels and tires.
Jason
