Router Resolving mDNS with nonsensical addressses
Hello! So I've been unpacking our teams KoP and setting up a freshly updated board and playing with the router. In some tests, I've noticed something peculiar about the router and how it resolves mDNS. The first time you request an address from it, it will return an IPv6 address that doesn't exist. The second time and subsequent times within an instanenous time frame will return an ipv4 address that is valid. For a visualization, see the command log
Code:
C:\Users\illid_000>ping roborio-1684-frc.local
Pinging roborio-1684-frc.local [fe80::280:2fff:fe17:6109%11] with 32 bytes of data:
Destination host unreachable.
Ping statistics for fe80::280:2fff:fe17:6109%11:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Pinging roborio-1684-frc.local [10.16.84.59] with 32 bytes of data:
Reply from 10.16.84.59: bytes=32 time=1ms TTL=63
Reply from 10.16.84.59: bytes=32 time<1ms TTL=63
Ping statistics for 10.16.84.59:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\Users\illid_000>
Is anyone else experiencing this issue? |
Re: Router Resolving mDNS with nonsensical addressses
While I can't attest to this specifically, we had an overall very... weird experience using the new router for RI3D. So this would not surprise me, and validates the issues we had.
I started investigating this issue after python deploy times went from 2s to ~30s with a huge hang on "finding robot". At this point I'd just go back to my 2015 mindset of "You get a static IP! You get a static IP! Everyone gets a static IP!!!" |
We experienced issues where a computer would disconnect, and refuse to re-establish robot communication upon reconnection unless the wireless card was taken down entirely (e.g. not just turning off wireless, the adapter had to be disabled and re-enabled or rebooted). This issue persisted across both tested computers (different wireless cards), although both were running Windows 10, so it is possible that the issue does not lie entirely with the router.
I want to note that we had to manually flash the firmware, as RI3D teams don't get an official KOP. It's possible that the firmware posted is slightly different than what shipped on the KOP router.
It's a possibility... we're testing right now but I'll reflash the router when we get back to building and see if that resolves anything
IPv6 fe80::/64 are link local addresses.
In IPv4 169.254.0.0/16 are the link local addresses |
#10
I remember in a prior year the Subnet mask causing delays. For competition, you need 255.0.0.0, which means the deploy program will search all possible team numbers. However, if you limit it to 255.255.255.0, then it will only search your team number for the robo rio.
#11
Reflashing the firmware on the radio did resolve the problems we were having. The IPv6 address that it pings to the first time around is actually valid and points to the RIO.
#12
Does that mean you're no longer having deploy issues?
#13
Yep. Deploy times are back down to 4-5seconds
