Mac install issue - not found in PATH
After doing an install via screensteps live, I was unable to get a build to work. I kept getting errors about the gnu cross compiler not being found
Code:
"arm-frc-linux-gnueabi-g++" not found in PATH ADDITIONALLY, I have seen the same issue others surrounding doing a 'clean' and the console says 'rm' was not found. On my Mac, 'rm' is found in /bin On my Mac, 'arm-frc-linux-gnueabi-g++' is found in /usr/local/bin So, here's the solution: Go to 'preferences' and select C++->Build->Environment : Click on 'Add...' Set 'Name' to 'PATH' Set 'Value' to '/usr/local/bin:/bin' Restart Eclipse Now 'Clean' should work and 'Build' should work on old and new projects. |
