Go to Post If you pay attention to every nut job on ChiefDelphi, you'll never reach a decision. - JesseK [more]
Unread 13-01-2016, 20:30
m1tche11d m1tche11d is offline
m1tche11d
FRC #1997
Rookie Year: 2010
m1tche11d is an unknown quantity at this point
No robot code on roboRIO
Our team is trying to deploy an example C++ program to the roboRIO, as per the instructions in the "Getting Started With the 2016 Control System" document, and are running into an error with actually getting the code onto the roboRIO.
When we deploy code to the roboRIO, our debug log has the following output:
Buildfile: C:\Users\DriveStation\workspace\getting_started\bu ild.xml
Trying to override old definition of task classloader
get-target-ip:
[echo] Trying Target: roboRIO-1997-FRC.local
[echo] roboRIO found via mDNS
dependencies:
[echo] roboRIO image version validated
deploy:
[sshexec] Connecting to roboRIO-1997-FRC.local:22
[sshexec] cmd : rm -f /home/lvuser/FRCUserProgram
[echo] [athena-deploy] Copying code over.
[scp] Connecting to roboRIO-1997-FRC.local:22
[scp] done.
[sshexec] cmd : killall -q netconsole-host || :
[scp] done.
[echo] [athena-deploy] Starting program.
[sshexec] cmd : . /etc/profile.d/natinst-path.sh; chmod a+x /home/lvuser/FRCUserProgram; /usr/local/frc/bin/frcKillRobot.sh -t -r;
[sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 10 seconds
Everything appears to be successful, however the roboRIO comm light is red (indicating no code) and the driver station still shows no robot code.
Last edited by m1tche11d : 13-01-2016 at 22:31. Reason: Edited to make problem more clear
Unread 13-01-2016, 20:37
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: No robot code on roboRIO
There's no error in the log.... the part where it says "Build Successful" means it succeeded.
Unread 13-01-2016, 21:03
m1tche11d
FRC #1997
Rookie Year: 2010
I understand that. However, the driver station is telling us that there is no robot code on the roboRIO in spite of the successful build log. No matter how many times we reboot the roboRIO or restart the code, it still is telling us (after a successful build log) that the robot has no code on it.
Unread 14-01-2016, 09:17
jtwilson jtwilson is offline
FRC #1730 (Team Driven)
Rookie Year: 2015
jtwilson is an unknown quantity at this point
We ran into the same error.
Are you using the simple robot template? If you are, try adding this code:
void Disabled()
while(IsDisabled()){}
and this:
void RobotInit()
it appears that these need to be overriden, or the robot will kill the process directly after you deploy it.
Unread 14-01-2016, 14:24
m1tche11d
FRC #1997
Rookie Year: 2010
No dice, same situation. The build log did change slighty (Also, I added the colors it prints in so it would be easier to read:
get-target-ip:
dependencies:
deploy:
[scp] done.
[scp] done.
[sshexec] killall: lvrt: no process killed
[sshexec] Remote command failed with exit status 1
BUILD SUCCESSFUL
We only got this specific log once, when I redeploy the code we get the same log as in the original post.
To me, it seems that the two colored lines near the bottom are telling me that the code deploy is cancelling for some reason, but I can't tell why it's doing so.
Unread 14-01-2016, 17:29
m1tche11d
FRC #1997
Rookie Year: 2010
Minor detail: the folder for our project has a small red x over it. I don't know if this is indicative of a larger problem or not.
Unread 14-01-2016, 18:00
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
And just to verify, this roboRIO has had its firmware updated (https://wpilib.screenstepslive.com/s...borio-firmware) and has been imaged (https://wpilib.screenstepslive.com/s...g-your-roborio), right?
(Taking guesses--I myself am new to this control system! )
Aren't signatures a bit outdated?
Unread 14-01-2016, 18:08
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
This thread looks similar.
http://www.chiefdelphi.com/forums/sh...hreadid=141652
Unread 14-01-2016, 21:00
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
Rookie Year: 2014
rod@3711 is an unknown quantity at this point
get-target-ip:
dependencies:
deploy:
[scp] done.
[scp] done.
BUILD SUCCESSFUL
I am having the same issue when trying to run the example mecanum program or arcade program. The Comm Light goes green for 1/2 second then red. I connected a usb camera to roborio, then tried the Simple Vision example and it ran as expected. Do not know the issue with drive programs.
Unread 15-01-2016, 02:23
jmullins16's Avatar
jmullins16 jmullins16 is offline
AKA: Jeff Mullins
FRC #2135 (Presentation Invasion)
Rookie Year: 2011
jmullins16 is an unknown quantity at this point
Originally Posted by JBotAlan View Post
FYI: This helped us... We are running again. Thanks.
Unread 15-01-2016, 15:10
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Can you try the following...
[1] Make sure a gamepad is connected and wired to slot 5 (the last spot) in the driver station. Change your source to use that slot, or just use an extra joystick/gamepad to ensure that slot is not empty. Either is fine.
[2] Then restart your project using the restart-robot-code, or redeploying.
Does that remove the crash symptom?
