Go to Post Why follow when you can lead? - Elgin Clock [more]
Unread 13-01-2016, 20:54
Blizzard3197 Blizzard3197 is offline
FRC #3197 (HexHounds)
Rookie Year: 2014
Blizzard3197 is an unknown quantity at this point
16 Inches vs 14 Inches? -Low Bar Question
So looking at the notes and doing some math, one of my teammates came up with this question:
The low bar's hole is 16 inches, however there is a foot ramp 3 inches tall, and using basic trig, the angled height of entry comes out to be somewhere around 14 inches or so.
And give a 2-5 inches for ground clearance, and some wheel diameters, and you're left with basically only an inch or two to work with.
Thoughts?
Unread 13-01-2016, 20:56
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: 16 Inches vs 14 Inches? -Low Bar Question
You've been sniped.
But yes, your math is sound.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
You are correct about the 14" "true" opening, but ground clearance is not added to the wheel diameter. Unless you're using some truly crazy wheels, any FRC drivetrain by itself should fit under just fine. It's the non drivetrain bits which make it tricky.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 13-01-2016, 20:58
Rookie Year: 2014
Thank you both for your responses. My teammate talked with our mentor, and we agreed that we would be able, due to Center of Gravity and only having 4 wheels, to fit under the bar; i.e. flop back down instead of sticking out straight.
Unread 14-01-2016, 05:52
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
What about coming back through the low bar from the other side? What kind of apparatuses would you have. It looks even shorter.
Unread 14-01-2016, 08:56
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
The short side of the low bar is facing the neutral zone. Always harder to get in the castle then it is to get out
Unread 14-01-2016, 09:45
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
You may want to have a look at the thread linked below. The low bar is not centered on the platform. Your wheels are not located such that their contact point with the floor is directly under the outer edge of your frame. This means that by doing some extra work, you can ensure that your robot to be as tall as possible to make it easier for you to package all your components and mechanism yet still pass under the low bar. If you get this wrong, you could be stuck on the competition field or you will have a hard time building and maintaining your robot.
http://www.chiefdelphi.com/forums/sh...d.php?t=141439
