Go to Post The numbers that I gave were purely theoretical and should not be considered realistic - Karibou [more]
Unread 14-01-2016, 00:59
ZMan78 ZMan78 is offline
ZMan78 is an unknown quantity at this point
[FRC] Laser pointer
Does anyone know if there are rules against having a laser pointer on your robot? We were thinking of putting one on to make it easier to launch the ball. Thanks
Unread 14-01-2016, 01:02
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Re: [FRC] Laser pointer
Ctrl+F search "laser" in the Game Manual PDF. There is exactly one result, which answers your question.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-01-2016, 01:05
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
R9, Blue Box D - Exposed lasers except Class 1 are prohibited. If you're looking for a quick and dirty way to aim, might I suggest a flashlight instead? Much safer, both literally and figuratively.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 14-01-2016, 01:52
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We tried to use a Class 1 laser a few years back for visual targeting. It was totally useless and almost impossible for the driver to see. The flashlight idea works much better.
Unread 14-01-2016, 02:13
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
You could also try a crosshair laser https://www.apinex.com/ret2/YCHG-650C.html
It should be easier to see than a laser dot.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 14-01-2016, 02:55
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
It was more an issue of it simply not being bright enough to see across the field in a well lit arena.
Unread 14-01-2016, 03:52
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
I believe that one of the criteria of being a class one "laser" is that it it's invisible.
Also the cross hair linked above is a class 2 or 3 "laser" so it is not legal per saft rules. However I will keep it in mind when arming my sharks with "lasers".
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 14-01-2016, 07:39
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Due to the restrictions on Laser Pointers, teams have used "photon cannons" (basically, BRIGHT flashlights) with focused beams. Mind you, there are still rules against blinding the opposing alliance (you're free to blind yourself).
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 14-01-2016, 08:15
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Not really, class 1 limits output power and frequency so that protective gear is not needed when the device is in use. Many invisible lasers can damage sight i.e. the lasers used in most CD/DVD players which are infrared.
BTW, when deciding on illumination, please consider the effect on other drivers. If your choice is determined to interfere with the sight of other drivers, you might be asked to remove or modify.
R9 ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition,
or interfere with the operation of other ROBOTS. See the blue box.
Al
WB9UVJ
www.wildstang.org
________________________
