Go to Post Are you confused yet? - Andy Grady [more]
Unread 14-01-2016, 08:35
onenerdyguy onenerdyguy is offline
FRC #5929
onenerdyguy is an unknown quantity at this point
Feasibility of Design by Rookie team?
Our team is designing a support robot, whose goal is to grab balls, traverse the defenses, and bring the ball to team mates who shoot. As such, we're designing for speed, low to the ground, and the ability to handle defenses. We're also going to try to hang.
The current plans are as such:
Low body using 6WD tank drive on Pneumatic wheels.
Ball-capture will be a pair of 'pincers' located on the front of the bot, which will actuate out and in to grab the balls with a largish half/dome shape. Once captured, it will actuate back a bit to lift the ball up to avoid contacting the ground will traversing. While not in use, these pincers will fold back over the main bot body for storage and to make sure they don't get jammed up on things.
Primary manipulator for the gate/sally port/draw bridge is a 'tail' . This tail will be driven by a chain drive and mounted on rods that span the length of our bot, allowing it to travel back and forth. This should allow us to, for example, hold the gate up and drive under neath it, keeping the 'tail' steady while our chassis goes under. Same idea for the sally port, and will allow us to lift our chassis up faster too we're hoping.
A very rough cad, completely not to scale, is here. Our team has had no cad experience, so they're doing all their work in TinkerCad right now while we get a hang of Solidworks. https://drive.google.com/open?id=0B3...3E5NlZwZmJlM00
Any and all feedback would be fantastic. The team is excited, but as you can guess, we're still learning tons!
Unread 14-01-2016, 08:57
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Feasibility of Design by Rookie team?
Your strategy look pretty viable. That's probably what i'd do being on a rookie team with low ressources/experience.
Basically you want to grab balls and interact with defenses using 2 different "arms". Do you think a single, stronger mechanism could do both tasks? Could you also find a way to score low goal with that same mechanism? There is so much stuff to think about
On a final note, keep in mind that a simple robot who does 1-2 tasks very well is better than a complex bot struggling at doing everything!
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 14-01-2016, 09:10
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Sounds like a solid strategy.
We always favor roller style ball pickups. The great advantage is not having to time the pickup with the presence of a ball. You can just run the roller, and when they drive up to it, it's automatically picked up. It makes ball acquisition much faster.
Unread 14-01-2016, 09:17
tprize tprize is offline
Team Founder
FRC #5586 (Bond Brigade)
Team Role: Leadership
Rookie Year: 2015
tprize is an unknown quantity at this point
Sounds like a solid strategy. We were rookie all stars at the Wisconsin Regional and at Worlds last year and all that I have to say is with a strategy like that make sure you get in as much driver practice as possible! With the extra time left (due to simple design) begin preparing all of your scouting as well as practice putting up your pit area and do mock judge interviews, because the judges are in charge of the Rookie All Star award. If you have any other questions feel free to PM me.
2016 Wisconsin Regional Creativity Award
2015 Wisconsin Regional Rookie All-Stars
2015 Curie Division Finalists (thank you teams 3663, 1574, and 2046)
2015 Curie-Carver Rookie All-Stars
Unread 14-01-2016, 09:25
FRC #5929
Our concern for a roller style is height. We're hoping to be able to do the low bar, and feel that with the height of the ball + roller + limits on extrusion from the bot, we'd not fit.
Unread 14-01-2016, 09:28
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
The diameter of the ball is 10", and if you're using a roller you're going to want to compress the ball slightly to make intake easier... say 1". That means the bottom of your roller is 9" off the ground, so the top of whatever apparatus you use could easily be under the 14" aperture of the low bar.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 14-01-2016, 09:36
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
Rookie Year: 2013
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
If you have a wheeled intake then you should be able to get low goal pretty easily. If you have a skilled driver (practice practice practice) then you have an excellent shot at doing really well.
Unread 14-01-2016, 09:47
FRC #5929
Looks like it might be time to work on a wheeled intake! We'll have to tweak our chassis size, but it appears doable.
With a wheeled intake, do you think we'd need to pull the ball 100% 'in' to a holding area kind of thing, or would pulling saying 4 inches of the ball and compressing it to hold it be sufficent? I'm looking at perimeter issues, potentially.
Unread 14-01-2016, 09:50
Drive Coach
AKA: Antoine L.
Rookie Year: 2012
just enough to make sure you don't loose the ball while crossing obstacles. I suggest you look up intakes from 2012 for inspiration
Unread 14-01-2016, 10:11
leon r leon r is offline
FRC #5422 (Stormgears)
Rookie Year: 1997
leon r will become famous soon enoughleon r will become famous soon enough
Definitely go with the roller ball intake! Much easier to use to use than "pincers"!
Also, when revered, rollers can score in lower goal (if you end up with allies who can't shoot).
Unread 14-01-2016, 10:31
howdosheeplamp's Avatar
howdosheeplamp howdosheeplamp is offline
I am the one who janks
AKA: Bijan Varjavand
FRC #2528
Rookie Year: 2013
howdosheeplamp is just really nicehowdosheeplamp is just really nicehowdosheeplamp is just really nicehowdosheeplamp is just really nice
If I was in your position I'd try to have at least some form of solo scoring potential - such as a reversible roller intake for low goal scoring. A lot of teams won't want to worry about getting out of their comfort zone if they pick you. Many successful teams will have their own plan for the whole 2:30, and might not want a robot that requires them to go out of their way and potentially mess up their cycles.
Unread 14-01-2016, 10:40
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'll pile on....pincers mostly push the ball away from you, while rollers suck it in. But you might want to play with the ball, and make a bumper, and see how the ball behaves when you drive into it, on carpet, with a bumper, at different heights. You don't really need a running robot to do this, you can fake it with some cleverness, some pieces of wood, and a student pretending he/she is the robot. Having a bumper will also help if you are working on designing a roller mechanism, because the ball pickup thingy will likely involve the bumper in it's design.
If you can deliver the ball to the low goal, you can also deliver it to an alliance partner. Design for both, and you can either help your partners, or score on your own.
Unread 14-01-2016, 10:50
FRC #5929
So, we've redesigned a little bit to change over to the Intake. Is this something what people were talking about?
Or would we want to have like a ramp to help feed the ball instead of the dual roller system?
https://drive.google.com/file/d/0B3S...ew?usp=sharing
Unread 14-01-2016, 10:49
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Traversing defenses and hanging can give you quite a bit of solo scoring potential.
I feel like having 67's approach of the 2012 game (balancing game with shooting basketballs instead of shooting basketballs with an end game) may be a great way to approach this year's game.
  #15   Spotlight this post!
Unread 14-01-2016, 12:29
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
This isn't really a support bot this would be a solid robot for scoring if you switched from pincers to a roller intake.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
