Go to Post Ok, so you are going to use a robot to hold all of those rivets together? - gblake [more]
Unread 14-01-2016, 11:56
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
Re: 67's 2010 Climber
Originally Posted by Kevin Leonard View Post
I was trying to find details on HOT's climber back in 2010 and how it was able to scale even after the end of the match. I couldn't find the relevant details on CD or their website. Can anyone direct me in the right direction?
Kevin,
I can't provide any helpful details, but here's the video I've been looking at recently while trying to understand their approach: https://www.youtube.com/watch?v=JI3N...=youtu.be&t=89.
Unread 14-01-2016, 12:24
Alex Guiamet's Avatar
Alex Guiamet Alex Guiamet is offline
FRC #3322 (Eagle Imperium)
Alex Guiamet has a spectacular aura aboutAlex Guiamet has a spectacular aura about
From my understanding there was some sort of gas spring that made the climber normally closed so that once it was hooked on, even if the match ended, it would finish scaling. We discussed how to possibly build a climber to do that but we're stuck on exactly how to go about it.
Kevin, you are correct about how 67's climber worked in 2010. I was a sophomore on the team that year and was one of the students who helped prototype it and build it.
Essentially we utilized four 200 lb gas struts (that were held back by a trunk latch we scavenged form GM's test vehicle scrap) that were connected to a rope and pulley system to pull our bot up.
In the match we just had to extend our arm up (while on the bump) and release our servo that held back our grappling hook to hang. One that servo was released, a 6 lb gas strut rotated a secondary arm that held onto the grappling hook by velcro. Once it had almost extended to its full length, a bike cable released the trunk latch causing the gas struts to extend, pull the rope in, and rip the grappling hook off the velcro so it could align with the center of the bot.
Does this help?
Unread 14-01-2016, 12:41
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Hmm, so that climber would be illegal per Question 504, yes?
That's...harder.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 14-01-2016, 13:34
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
That's...harder.
Thanks for pointing that out. I didn't initially look at the 15" rule that way. But that answer to me says dangling a short robot (like 67's) from a winch cable is not legal.
By the way, 67's hanger in 2010 was awesome to watch!
David
Unread 14-01-2016, 12:45
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
We used 4 gas struts that were used with a reverse block and tackle system to pull ~36" of rope. It wasn't as easy as it looked. It took us 3 design iterations to get the pull force and the amount of rope pulled right to get a legal hang. It was also huge, being roughly 4" x 6", starting at around 21" and expanding to 36" in length within the frame.
We were just laughing about this the other night as the energy we used to hang actually came from a student. It had a giant crank we used to just pull on the hang rope until the struts were compressed, then just re-latched it.
It is a tremendous amount of stored energy, and must be treated with great care. The benefit of gas struts is they only release that energy relatively slowly though, so it's not too bad. We buried ours inside the frame and latched it with a cross-bar and car trunk latch.
The thing about hanging in 2010, was that it was of such a low point value that it only made sense to do at the last second. Roughly the equivalent of if scaling was only worth 2 points this year. Also, my interpretation of the rules make it so that it wouldn't count. I think the final explanation will be that you have to be up at the end of the match and stay up for 5 seconds for it to count. You really need something like that to be able to judge it, otherwise people would just let their motors back drive at the buzzer.
Unread 14-01-2016, 13:02
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
Sounds like a good Q&A question. The 15 points for the hang feels to me to be weighted about the same as the hang was in 2010 in comparison to the rest of the game.
I'm working through a few designs in my head of how to make this work and it just sounds complex to develop, especially in comparison to the design we have currently mocked up.
So the systems involved were essentially: something to extend the climber, something to release the gas springs, and a way to crank it all back in safely.
Am I missing something?
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
Unread 14-01-2016, 14:21
Jim Meyer's Avatar
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
My memory could be incorrect, but wasn't the hang worth the same as one scored soccer ball?
I think that's the gist of it.
Our climber was the most Rube Goldberg machine we've ever built. The only electronic component of our hanger was a single servo to deploy the hook. Once the hook arm started swinging, the rest was a mechanical process. The swinging hook arm pulled a bike cable that turned the trunk latch that released the gas strut rope winch.
Unread 14-01-2016, 14:23
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
In 2010 it was worth two scored balls (2 points per robot hanging).
So its worth three high goals this year.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 14-01-2016, 14:30
Jim Meyer's Avatar
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
Yes, that makes sense. It seemed to take a lot less effort to score a soccer ball that year though, as you didn't have to cross the bump yourself for each ball. We would not take the time to set up the hang if there were available balls to shoot.
Unread 14-01-2016, 14:36
Chris is me's Avatar
AKA: Pinecone
Well, no, it's really worth two high goals + parking on the platform (which very well might be a place you're shooting those high goals from). Very similar to 2010 in terms of point value when you realize it's just two scored balls more than the alternative.
Unread 14-01-2016, 14:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Every time you put your rewind-structure on the top of the bot and your students started cranking, we joked about what they must have done to make you hate them so much
