Go to Post FIRST is not all about the robot, it's about the experience. Don't sour yours by whining about it later. - StephLee [more]
  #16   Spotlight this post!
Unread 02-27-2016, 08:49 PM
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Re: Permission denied when pushing code
This popped for us today, any ideas?
Brian K
Team 1225 Robotics Mentor
  #17   Spotlight this post!
Unread 02-27-2016, 09:22 PM
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
I just got ours to work...but I don't really know what I did.
I reflashed firmware and reimaged the roboRIO multiple times using our driver station Classmate and my programming laptop. No dice.
I swapped the roboRIO with another one - no dice. Same problem.
I got a completely different laptop, updated the WPI plugins, tried to deploy, no dice.
I used the same laptop to reflash and reimage the roboRIO. I deleted the project from the workspace, then reimported it and rebuilt. At this point, it downloaded. I am not even sure that action contributed to the fix.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
  #18   Spotlight this post!
Unread 02-28-2016, 02:51 AM
O-H
Anyone experiencing problems, please cross-post details to the FIRST Forums thread here - http://forums.usfirst.org/showthread...-During-Deploy.
Time to make it loud.
  #19   Spotlight this post!
Unread 02-28-2016, 10:54 AM
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
If you're familiar with Linux, could you try ssh-ing to the roboRIO as lvuser and check the permissions and ownership of files in the lvuser home directory and look for anything not owned by lvuser. It seems like somehow something is getting messed up, maybe a a download failing part way through or something.
If not, I would expect that reimaging and being sure to check the reformat box in the imaging tool would get you back. If you do that, be sure to reinstall Java if that's the language you're using.
Brad
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
  #20   Spotlight this post!
Unread 02-28-2016, 01:37 PM
SuperBK's Avatar
AKA: BrianK
We SSH'd to the roborio as admin, then did
chmod -R 777 /home/lvuser/
To give all users read, write, and execute permissions to the folder.
lvuser was not the owner of the /home/lvuser/ folder, to we gave all permissions to everybody.
Its now working for us.
Brian K
  #21   Spotlight this post!
Unread 02-28-2016, 01:51 PM
LG67 LG67 is offline
LG67 is an unknown quantity at this point
Spent a gazillion hours last night trying to fix the exact same problem and your solution is a life-saver. Thank you
  #22   Spotlight this post!
Unread 02-28-2016, 02:34 PM
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Next time someone has an issue, please log into the roboRIO run the following command and post the output here.
Log in as admin@roboRIO-<team#>-frc.local with putty or equivilent
Then, run
Code:
ls -lah /home/lvuser/
And post the results.
  #23   Spotlight this post!
Unread 02-28-2016, 03:25 PM
SuperBK's Avatar
AKA: BrianK
After updating the Eclipse plugins, we were broken again. Something, during the deploy process is TAKING AWAY the permissions for lvuser to the /home/lvuser/ folder. This happens during or before the "killall" command.
Our fix was to modify the build.xml file and add permissions back to the lvuser folder before the copy of the code over. Note that the user "admin" is used to add the permissions back, not "lvuser"
Here is a snippit of the build.xml. We added this part
<sshexec host="${target}"
username="admin"
password="${password}"
trust="true"
failonerror="false"
command="chmod 777 /home/lvuser"/>
Code:
               username="admin"
               trust="true"
               failonerror="false"
               command="killall -q netconsole-host || :"/>
  	               username="admin"
  	               trust="true"
  	               failonerror="false"
    <scp file="${wpilib.ant.dir}/robotCommand" todir="${username}@${target}:/home/lvuser/" password="${password}" trust="true"/>
Brian K
  #24   Spotlight this post!
Unread 02-28-2016, 03:45 PM
SuperBK's Avatar
AKA: BrianK
I attached my build.xml file. (remove the .txt extension)
Brian K
  #25   Spotlight this post!
Unread 02-28-2016, 10:31 PM
carrud carrud is offline
AKA: Clark Rudder
FRC #2637
Rookie Year: 2014
carrud is an unknown quantity at this point
This partially worked for me. This exact placement did not resolve the Permission Denied, but moving the line to a diff spot in the .xml worked great.
BTW, for others: this .xml for me is in wpilib/cpp/current/ant
Many thanks for posting this fix.
-Clark
  #26   Spotlight this post!
Unread 02-29-2016, 03:06 PM
rod@3711 rod@3711 is offline
AKA: rod nelson
FRC #3711 (Iron Mustangs)
Rookie Year: 2014
rod@3711 is an unknown quantity at this point
I am now getting the Permission Denied feature when trying to deploy. Started today after I allowed eclipse to upgrade from 4.5.1.20150917-1200 to 4.5.1.20160218-0600.
I Tried "reverting" back in Eclipse.
I tried using FileZilla to allow all permissions to home/lvuser. My changes did not seem to stick.
I tried changing changing build.xml that is ..wpilib\cpp\current\ant adding:
<sshexec host="${target}" command="chmod 777 /home/lvuser" failonerror="false" trust="true" password="${password}" username="admin"/>
at random locations.
I tried updating the firmware in the roboRio.
I did not feel comfortable that I did any of the above steps correctly, but I am still unable to deploy code.
I will try deploying with another computer this afternoon.
  #27   Spotlight this post!
Unread 02-29-2016, 04:11 PM
SuperBK's Avatar
AKA: BrianK
You may have to ssh to your roboRio first and issue the "chmod 777 /home/lvuser" to give permission to the folder, then run the modified build.xml. . After issuing the command you can do
ls -l /home/lvuser
and see if the permissions are "drwxrwxrwx" to see if your changes take.
Do you need step-by-step instructions on how to ssh to it? I use putty, a ssh client.
After doing that, try deploying again. Post the entire contents of your build log here.
Do you see se the extra chmod command in your build log?
Add exactly this (cut and paste)
username="admin"
trust="true"
failonerror="false"
Above the line
Brian K
  #28   Spotlight this post!
Unread 02-29-2016, 05:16 PM
AKA: rod nelson
Rookie Year: 2014
Thanx Brian,
When I had previously tried to set permissions with filezilla, I had logged on as lvuser. It probably did not the right privileges. Logged on as admin and the permission changes stuck.
Added your "chmod 777" to build.xml and voila.
You will be receiving good karma credits.
  #29   Spotlight this post!
Unread 02-29-2016, 05:39 PM
O-H
I THINK THIS IS KEY. The computer that works and deploys code has MARS.1 installed (4.5.1.20150917-1200). The computer that started flaking out and throwing permission denied errors has MARS.2 (4.5.1.20160218-0600), which I installed shortly prior to this problem occurring.
I will use the build.xml hack in an emergency, but I hope the developers investigate this potential blar with Eclipse developers.
  #30   Spotlight this post!
Unread 03-01-2016, 12:53 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
Rookie Year: 2010
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
We're seeing this same issue here at 116. I wiped out the updated Mars.1 eclipse and installed Mars.2 with the exact same results -- permission denied. I still have the original Mars.1 install package. I'll try that, but I suspect that it will work until the update rolls in.
Mike A.
Mentor
FRC #116
