Go to Post For guys, is the appropriate term "manpris". ? - Chris Fultz [more]
Unread 14-01-2016, 14:24
lnex1357's Avatar
lnex1357 lnex1357 is offline
Inspiration through Determination
AKA: Joshua Miller
FRC #2168 (Aluminum Falcons)
Team Role: Coach
lnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud of
Send a message via AIM to lnex1357
VPro Live Axle 1 Colson 0 Turn Down Your Hubs
So the 6" colson handles VPro Dead axles just fine. Live ones out of the box? Well that would require and extension handle on your press and pulling your back or throwing them in the lathe. Otherwise its a long for the Colson.
Clarkson University 2010 / GENERAL DYNAMICS Engineer / EWCP / FIRST Volunteer
FRC Team 2168 - Aluminum Falcons, [2011-20xx]
FRC Team 229 - Division By Zero, [2004-2010]
"Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek."
Unread 14-01-2016, 14:44
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
Re: VPro Live Axle 1 Colson 0 Turn Down Your Hubs
Strange, we didn't run into this issue in 2014 with any of the 8 6" Colsons we pressed live hubs into (using a hydraulic press) They're designed to be an interference fit to ensure they don't slip.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-01-2016, 14:57
ToddF's Avatar
ToddF ToddF is online now
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
We used these hubs and wheels last year, and had no problems also.
Correction: Our wheels were 6"x1.5". Maybe the 2" wheels are different somehow.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 14-01-2016, 15:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Were you supporting the hub of the colson close to the center when pressing? or farther out at the tread? If the latter, I wouldn't be surprised that you cracked them.
2001-2004: Team 100
2006-Present: Team 254
Unread 14-01-2016, 15:02
Rookie Year: 2010
You reminded me, we used the 6x1.5 as well.
According to the product data on robotmarketplace.com, they should have the same bore though. Strange.
Unread 15-01-2016, 08:24
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is online now
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
If you go to Other Documentation > Assembly Instructions, it pulls up a datasheet from VexPro with the following:
Note: The Colson Live Hub is designed to be pressed into the bore of Colson Performa Wheel. There is a
.0125” interference fit between the hub and bore of the Colson Wheel. This will require an arbor press or
large vise to assemble. It is NOT recommended to hammer the hub into the bore, as this can lead to damage
and misalignment between the hub and wheel.
You'd think they'd make that info readily accessible though...
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
