Go to Post You only get one first post. ;) - gvarndell [more]
Unread 02-08-2002, 00:25
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Rodless Cylinder
Instead of taking the FIRST Forum thread off topic i'll just post what i'm pretty sure they are talking about....
sanddrag
What is a rodless pneumatic cylinder?
Nate's Forum Notes
Pneumatics-add rodless cylinder
Rodless Cylinder from Festo
The only reason i'm kinda sure this is what they are talking about is because Andy Baker had one of these that he was supposed to show someone at Nationals....
PS. I may be wrong
Purdue Alumni
Cummins, Inc.
Unread 02-08-2002, 00:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Thanks but I still don't really get it.
Unread 02-08-2002, 06:46
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
From what I can tell, it acts basically like a Chinese Finger Trap. Positive pressure forces the cylinder to extend, and negative pressure forces the cylinder to contract.
But...
It's 4am, I may not understand what the hell I'm talking about, and it might operate in an entirely different way...
/me should go to sleep...
If you want a coherent reply, as opposed to this one, please tell me... I might be able to decipher what I meant tomorrow/later today, sometime...
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 02-08-2002, 08:16
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
i think it may be the other way around, where positive pressure contracts it, and negative expands. it's like a chinese finger trap in that when you push in, it contracts in length, and expands in diameter, and you get out, but when you pull, it just gets longer and smaller in diameter. now, this may completely wrong (heck, i'm a programmer ), but i think it's right.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 02-08-2002, 10:53
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
We also use what can be know as a 'rodless cylinder' in the plant for very long stroke applications. (about 10ft)
Think of a long fixed length cylinder. Cut a groove along the entire length that completely through the cylinder material. Now place a shuttle inside the cylinder that has the same diameter as the inside bore of the cylinder.. Lastly you put some sort of a seal over the groove that unseals at the location of the shuttle then seals on both sides of the shuttle as the shuttle moves back and forth. Applying air pressure to either side moves the shuttle the length of the cylinder yet there is no piston inside just the shuttle.
Ohh well this is another version of a 'rodless cylinder'
Matt
Unread 02-08-2002, 15:06
I love browsing CD at 4am...
Unread 02-08-2002, 17:47
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
I read something in a book that was like this only it wasn't called a roddless cylinder it was called "air muscle" basicaly a tube than can expand and contract like a arm or leg muscle.
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 02-08-2002, 19:39
If you download the program that is linked to on the page that Clark posted, you can see a few small animations of how the cylinder is supposed to work, and <edit>oh boy!</edit> does it look sweet...
/me awaits next year's kit with much anticipation...
<edit>
here's a link to the download page for the program:
http://www.festo.com/INetDomino/coor...410050e38e.htm
</edit>
Unread 02-08-2002, 23:17
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
What about what they gave us in 2000 it was a pneumatic cylinder that had a magnet or somthing in in it that would slide around the cylinder. Mmm bad explination if you look in Ed Spark's Cad library under archive you will find it there. This more than likely is what they are talking about. http://www.firstcadlibrary.com/pages/archive.asp Scroll down it looks like this :
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 16-08-2002, 12:15
Dan 550's Avatar
Dan 550 Dan 550 is offline
Behold the Awesomeness!
AKA: Dan Richards
#0550 (BattleTech)
Rookie Year: 2000
Dan 550 is on a distinguished road
soooooooooo nice. I just got another plan... hehehe.
Unread 01-11-2002, 22:05
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: Rodless Cylinder
sanddrag
They're also called "Air Muscles"...
Mechanically, imagine a cylindrical balloon in a fishnet mesh wrapper, like a bag of oranges, or the chinese finger trap. When you inflate the balloon with pressure, the center of it expands. However, the mesh wrapper attempts to keep the balloon the same volume. The shape changes from cylindrical toward spherical, with constant surface area. Therefore, as the center inflates, the ends of the mesh wrapper must pull toward each other.
If one side of the mesh is attached to the inflation nozzle end, and the other end to a metal collar, ring, or other attachment endpiece, they'll pull toward each other as the muscle inflates.
Now that you see that, dip the mesh wrapper in rubber. The mesh/rubber combo now is more like the reinforcing belts within a vehicle tire. However, it still works the same way. The rubber simply creates a protective coating over the flexing mesh. I believe this is the kind of Air Muscle Festo provides, but I'd have to check to be sure.
If you wish to make an Air Muscle for yourself, check out this page:
http://www.imagesco.com/articles/air...ription01.html
I think it would be VERY cool if the Allowed Extra Materials list would allow the creation of Air Muscles!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Making a series of spaced holes around a cylinder in inventor James114 Inventor 13 21-11-2004 18:44
Is 'using a smaller cylinder' really that easy?? mjt902 Pneumatics 4 29-01-2003 16:13
can i use any other custom cylinder MAXbattlebot Pneumatics 2 19-01-2003 12:44
roadless cylinder doomsdaytank Pneumatics 2 16-01-2003 16:52
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
