Go to Post "THAT'S NOT SAFE!" "But I'm wearing safety goggles!" - Samheartsrobots [more]
Unread 14-01-2016, 15:25
fruitcup fruitcup is offline
FRC #5212
fruitcup is an unknown quantity at this point
Bumper clarification
My team is a little confused on R19:
ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER.
For adequate protection, at least 8 in. of BUMPER must be placed on each side of each outside
corner (see Figure 4-3). If a side is shorter than 8 in., the entire side must be protected by
BUMPER (see Figure 4-4). A round or circular FRAME PERIMETER, or segment of the frame
perimeter, is considered to have an infinite number of corners.
Does this mean that all corners must have at least 8" on each side, or only that if the side is < 8", then the whole side must be covered in bumpers.
I am specifically asking about the scenario below, where there is a gap in the front of the robot. Can the 2 sides surrounding the gap be less than 8" in length (e.g. 4")?
Clarification would be greatly appreciated!
Unread 14-01-2016, 15:31
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
Team Role: Teacher
Rookie Year: 2011
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: Bumper clarification
From Q&A:
Q520
Q. Bumper rule R19 states "If a side is shorter than 8 in., the entire side must be protected by BUMPER". If the side is 27" with a 13" cut-out (14" remaining) does the 8" minimum apply or is the 7" on either side of the cut-out considered a full side less than 8"?
A. Per the Blue Box below R19: the dimension defined in R19 is measured along the FRAME PERIMETER. A lack of physical frame elements between corners of the FRAME PERIMETER does not change the length of the FRAME PERIMETER side.
Unread 14-01-2016, 15:45
FRC #5212
Originally Posted by MrJohnston View Post
From Q&A:
Q520
So that would mean that the 4" on either side scenario would be acceptable (4+4>=8) but anything less would violate R19?
That is how my team is interpreting that answer, which is contrary to what Jacob suggested.
Unread 14-01-2016, 15:48
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
You would need 8 inches on each side, the cutout would have no bearing on how the frame perimeter is calculated.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-01-2016, 15:49
FRC #5212
Got it. Thank you all.
Unread 14-01-2016, 15:33
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Rookie Year: 2007
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
As far as I understand it, no. The front of the robot in your picture is longer than 8" therefore 8" of it must be covered by bumper.
In addition per R26 Bumpers must be backed by at least 1/2" on each end. For your drawing to be legal the two 4" sides would have to be at least 8". Anything more than that can be an unbumpered opening.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Unread 14-01-2016, 16:08
GaryVoshol's Avatar
Happy Birthday! GaryVoshol GaryVoshol is offline
Cogito ergo arbitro
Rookie Year: 2000
That picture does not have two 4" sides. The "front" side with the gap is the same length as the "back" side with no gap, maybe 18 inches or so extrapolating. The front and back 18" sides each must be protected 8" from each corner. And since the BUMPER must attach firmly to underlying structure, that picture can't work.
That's what QA520 (quoted above) says.
(since 2004)
Unread 14-01-2016, 16:32
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
"at least 8 in. of BUMPER must be placed on each side of each outside corner"
This rule is surprisingly clear when read carefully.
The key is understanding what "each side of each outside corner" means. It means that for every extreme convex corner of your frame, the edges that intersect at that corner must have 8 inches of bumper starting from the point of intersection and ending at a minimum of 8 inches in the direction towards the opposing end of each respective edge.
Basically, any given side of a robot will have at least 16 inches of bumper, as each corner of that side will have a minimum of 8 inches.
