Go to Post It shows more than anything, that there are students out there that want to learn, to do better, to improve their own lives and those around them. Thankfully, FIRST is there to help them realize some of their goals. - Al Skierkiewicz [more]
Unread 14-01-2016, 17:35
simon1636 simon1636 is offline
FRC #4501
simon1636 is an unknown quantity at this point
Autonomous Timer
Hi! I'm working on some autonomous code for my robot. The code is to drive forward. In the code, it should be under the function driveForward(). Anyways, what I would like to do is to be able to make it drive forward at a certain speed for a certain amount of time. I have the speed down, and it's driving. I just need to know how to do the timed stuff. Sorry if it's a pretty basic question. I just started programming autonomous and I have never done this before.
Here is the code that includes driveForward():
Code:
package org.usfirst.frc.team4501.robot.subsystems;
import org.usfirst.frc.team4501.robot.RobotMap;
import org.usfirst.frc.team4501.robot.commands.DriveArcade;
import edu.wpi.first.wpilibj.AnalogGyro;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.DoubleSolenoid.Value;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.command.Subsystem;
public class DriveTrain extends Subsystem {
	public enum ShifterState{
		SF_HIGH, SF_LOW;
	RobotDrive drive;
	Talon rightTalon;
	Talon leftTalon;
	DoubleSolenoid shifter;
	ShifterState state;
	AnalogGyro gyro;
	Encoder L_Encoder;
	Encoder R_Encoder;
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
    public DriveTrain(){
		this.leftTalon = new Talon(RobotMap.LEFTMOTOR);
		this.rightTalon = new Talon(RobotMap.RIGHTMOTOR);
		this.drive = new RobotDrive(leftTalon, rightTalon);
		this.shifter = new DoubleSolenoid(RobotMap.SOLENOID_HIGHGEAR, RobotMap.SOLENOID_LOWGEAR);
		this.gyro = new AnalogGyro(RobotMap.GYRO);
		this.L_Encoder = new Encoder(RobotMap.Encoders.L_A, RobotMap.Encoders.L_B);
		this.R_Encoder = new Encoder(RobotMap.Encoders.R_A, RobotMap.Encoders.R_B);
    public void initDefaultCommand(){
    	setDefaultCommand(new DriveArcade());
    public void arcadeDrive(double forward, double rotate){
    	drive.arcadeDrive(forward, rotate);
    public void initGyro(double gSensitivity){
    	gyro.initGyro();
    	gyro.reset();
    	gyro.setSensitivity(gSensitivity); //volts Per Degree Per Second
    public void sensorReset(){
    	gyro.reset();
    	L_Encoder.reset();
    	R_Encoder.reset();
    public void getSensors(){
    	long gyroAngle = Math.round(gyro.getAngle());
    	SmartDashboard.putNumber("Gyro Angle", gyroAngle);
    	SmartDashboard.getNumber("Gyro Rate", gyro.getRate());
    	SmartDashboard.putNumber("Right Encoder Distance", this.R_Encoder.getDistance());
    	SmartDashboard.putNumber("Left Encoder Distance", this.L_Encoder.getDistance());
    	SmartDashboard.putNumber("Right Encoder Rate", this.R_Encoder.getRate());
    	SmartDashboard.putNumber("Left Encoder Rate", this.L_Encoder.getRate());
    public void highGear() {
    	shifter.set(Value.kReverse);
    	state = ShifterState.SF_HIGH;
    public void lowGear() {
    	shifter.set(Value.kForward);
    	state = ShifterState.SF_LOW;
    public void set(ShifterState state) {
    	switch (state) {
    	case SF_HIGH:
    		this.highGear();
    		break;
    	case SF_LOW:
    		this.lowGear();
    		break;
    public ShifterState getState() {
    	return state;
    public void forwardMove(double x, double y){
    	this.leftTalon.set(x);
    	this.rightTalon.set(y);
Here is the code which includes the autonomous section:
Code:
package org.usfirst.frc.team4501.robot;
import org.usfirst.frc.team4501.robot.commands.DriveIdle;
import org.usfirst.frc.team4501.robot.subsystems.DriveTrain;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
	public static OI oi;
    Command autonomousCommand;
    DriveTrain drive;
    // Subsystems
    public static final DriveTrain driveTrain = new DriveTrain();
    public void robotInit() {
		oi = new OI();
		driveTrain.initGyro(.0069);
	public void disabledPeriodic() {
		Scheduler.getInstance().run();
    	driveTrain.sensorReset();
    	// schedule the autonomous command (example)
        if (autonomousCommand != null) {
        	autonomousCommand.start();
     * This function is called periodically during autonomous
        driveTrain.forwardMove(0.05, 0.05);
    public void teleopInit() {
		// This makes sure that the autonomous stops running when
        // teleop starts running. If you want the autonomous to
        // continue until interrupted by another command, remove
        // this line or comment it out.
        if (autonomousCommand != null) autonomousCommand.cancel();
        Scheduler.getInstance().add(new DriveArcade());
     * This function is called when the disabled button is hit.
     * You can use it to reset subsystems before shutting down.
    public void disabledInit(){
    	Scheduler.getInstance().add(new DriveIdle());
     * This function is called periodically during operator control
    	driveTrain.getSensors();
     * This function is called periodically during test mode
    public void testPeriodic() {
        LiveWindow.run();
Thanks!
