Re: [Ri3D] Team Indiana Presents: Veronica
The foam directly under the skin "crumples" slightly after many shots. You can feel the difference when you squish them by hand. |
What was the length of each pieces of the double jointed arm?
So the curse of 2012 strikes again. Hopefully FIRST doesn't decide to source from a new manufacturer midway through the season this year as well.
How much compression were you getting on your balls? (distance from shooter wheel surface to curved backplate) Thank you for your insights! :-) |
This question makes me want to run the math for the situation where the Shovel the fries™, is in the middle position to find the speed the robot would have to carry to make it to the bar...
Thanks. We'll be posting a 3D pdf as well as some other resources, but not a full CAD. Last edited by BoilerMentor : 15-01-2016 at 09:18. |
Any update on the 3D pdf?
The 3D PDF is ready!
You will need to download it and open it IN ADOBE to view it properly. Check it out HERE -Team Indiana |
Hi PurpleINK,
THe PDF that was posted opens as a blank document with the SOLID WORKS statement at the bottom of the document. Do i need a special viewer for this PDF? Thanks |
Are you opening it in your web browser, or with Adobe? You have to download it and open it with Adobe reader to be able to enable the 3D content.
#10
At the top of that page, you'll need to click the 'Download' button. It looks like an arrow pointing down towards a line. Once it has downloaded, simply open it. I hope this helps! |
#11
Hanging/Scaling was our lowest priority after analyzing the scoring breakdown. There's plenty of space and weight to add a climbing mechanism if we had had more time.
#12
Once again, probably the best Ri3D team. You guys have set the standard for a strong Stronghold robot. Do you have CAD for the bot you can post? I'm curious to see how you got that shooter crammed in there.
