Go to Post Or, to put it another way: It's a sport where you build your own athlete. - EricH [more]
Unread 14-01-2016, 19:34
Razer0901's Avatar
Razer0901 Razer0901 is offline
FRC #5735 (Control Freaks)
Team Role: Leadership
Rookie Year: 2015
Razer0901 is an unknown quantity at this point
Question about Climbing the Tower
Hello everyone,
As a second year team, we are looking for advice for mechanisms to climb the tower. We are looking into using an elevator like what many teams used in 2011 for their lift (eg. 254's) , but without a reference we have no idea what kind of gearbox/motors we would need to lift up our robot (120 lb)
I understand that without knowing the sizes of the drum or the lift configuration it would be hard to determine the gearing and ratio of the power, but could anyone tell us what we would be looking at for power? CIMs? MiniCIMs? 1:10? 1:50? 1:75? Also, if ratio goes above 1:10 what kind of COTS gearboxes are we looking at since drivetrain gearboxes are usually 1:10, and VersaPlanatary can't take CIMs above 1:50ish based on the recommendations.
Also could people provide insight into successful climbers in general and how they were implemented? I have seen 1114's 2013 climber, 254's 2013 climbers, as well as many others, but I don't understand how they work. (eg. Winch? Direct chain drive?) Even if they don't directly apply to this year's game, they could be useful info into climbers in general.
Thanks!
-Razer0901
Unread 14-01-2016, 19:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Question about Climbing the Tower
In 2010 (Breakaway), we lifted our robot using a single CIM motor, geared through a DeWalt transmission and attached to a boat winch. http://www.thebluealliance.com/match/2010mo_qm64
In 2013 (Ultimate Ascent), we lifted up all 3 levels using 2 mini-CIM's geared through a Toughbox Mini, and attached to a homemade winch. http://www.thebluealliance.com/match/2013mndu_qm77
Let me know if you want any more details about our mechanisms!
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 14-01-2016, 20:16
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Originally Posted by Razer0901 View Post
Hello everyone,
Thanks!
-Razer0901
Use the JVN calculation spreadsheet that is published on ChiefDelphi. There is a "Linear Mechanism" tab that allows you to select motors, gear ratios, pulley diameter, number of motors used, load, and distance. The spreadsheet will calculate estimated speed and motor load. Load the motor at no more than 25% of stall amps is a good rule of thumb.
http://www.chiefdelphi.com/media/papers/3188
This is a great "Behind the Lines" presentation on motor gear selection with Ken Stafford and the GameSense crew.
https://www.youtube.com/watch?v=WPX3z-qLSk0
Good luck with your build season!
David
Unread 14-01-2016, 22:26
Razer0901's Avatar
Rookie Year: 2015
Thanks for all the responses! Will look into the resources provided!
Thanks!
-Razer0901
