Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 15-01-2016, 17:14
Bkelly28 Bkelly28 is offline
FRC #2603
Bkelly28 is an unknown quantity at this point
Labview and SmartDashboard
I've been trying to make an autonomous picker in SmartDashboard, but I dont have any SmartDashboard functions. What do I need to do?
Unread 15-01-2016, 21:09
Re: Labview and SmartDashboard
The LV network table functions can read any variables and all supported types. But I don't know the name of the picker.
I'd use the Variables tab or a table viewer for SD to see where the picker value is stored, then read the variable when you need it.
By the way, the default dashboard has an auto picker on the Drive tab. In Begin, you add your auto names to the array of strings. They will show up in the picker, and once selected, the auto reads the variable and switches on it. The custom LV dashboard has this in it as well.
Greg McKaskle
