Go to Post Both might accomplish the same "function" or "results" (perhaps a lift of some kind), but there are clear differences in simplicity, in cost, in maintainability, extensibility, and several other "ilities" -- which are a staple of engineering evaluation criteria. - msd [more]
Unread 15-01-2016, 19:09
faraz5557's Avatar
faraz5557 faraz5557 is offline
BB-R8ER
AKA: Faraz Masroor
FRC #5557 (BB R8ERS)
Rookie Year: 2015
faraz5557 is an unknown quantity at this point
Question Wifi router radio sometimes resets
My team has made a test robot with the radio router (on page 6, 2nd from top.) We can control it fine with the joystick, when we turn the robot on the the wifwe can connect in like a minute so it works. But sometimes when we test it the wifi just randomly resets. The lights on the velocity controllers stay on, so its not a power issue, but the lights on the wifi radio just turn off and after a little bit it turns back on. What's going on, is this an electrical issue?
Unread 15-01-2016, 19:21
Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
Re: Wifi router radio sometimes resets
Where is the radio power connected? Make sure it is connected to the 12V/2A output of the VRM, not directly to one of the PDP outputs.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
Unread 16-01-2016, 00:17
faraz5557's Avatar
BB-R8ER
AKA: Faraz Masroor
Rookie Year: 2015
I'm not sure about the robots connectivity. I'll get back to you tomorrow morning and see what's up.
Thanks for the response!
Unread 16-01-2016, 10:31
faraz5557's Avatar
BB-R8ER
AKA: Faraz Masroor
Rookie Year: 2015
Thanks for waiting. It turns out the WiFi router is already connected to the 12V/2A output of the VRM.
Unread 16-01-2016, 17:08
Dartmouth 2020
AKA: lopsided98
Rookie Year: 2011
I would check to make sure no wires are loose, but other than that I don't know what could be wrong.
Unread 20-01-2016, 13:25
Pike3543's Avatar
Pike3543 Pike3543 is offline
Coder
AKA: Connor
FRC #3543 (C4 Robotics)
Rookie Year: 2014
Pike3543 is an unknown quantity at this point
Do you have a camera hocked up? We are having the same problem and think it may have something to do with it.
Unread 20-01-2016, 17:31
faraz5557's Avatar
BB-R8ER
AKA: Faraz Masroor
Rookie Year: 2015
Sorry for not updating. We think we have solved the problem. We changed the wires that we used in connecting various parts of the robot to the power supply. According to the field manual or something, the proper size is 18 gauge, whereas we used 22 gauge wire. I could have this backwards, as someone else in my team figured out the solution. So check to make sure you have the proper type of wires on your robot.
We do not have a camera but we are considering it.
