Go to Post No disclaimer on earth lets you disassociate yourself with your team or what you represent because you want to say something not particularly nice, but lets you be associated again when you want to say something to encourage others, etc. - Amanda Morrison [more]
Unread 15-01-2016, 19:37
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Passive POE
Originally Posted by R43 Blue Box
Note that this prohibits using any POE Injector device to power the radio, but does not prohibit using any PASSIVE CONDUCTORS to inject the VRM power into an Ethernet cable plugged into the radio port labeled “18-24v POE”.
Has anyone thought about using passive POE injectors to power the new Radio? Anyone have a favorite model?
I personally prefer RJ45s to barrel jacks any day, so I'm very interested in eliminating them if possible.
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 16-01-2016, 00:38
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: Passive POE
We just bought a set of these. This is the official injector sold by the company that makes the radio.
We'll report in once we test the injector.
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 16-01-2016, 06:44
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Passive POE
I didn't really understand the box. Open Mesh makes and supports the ideal device that you can't use. It's only one item to add and reduces the connections at the radio. A great idea, but can't be used.
It's possible to use the extra wires in the cable with the work around adapters posted above. I've used similar ones (mine come from Adafruit for $5.95+shipping with good success in non-mobile applications. But only needing one end would be good.
Any ideas why the GDC decided to not allow the Open Mesh device?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 16-01-2016, 20:43
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Rookie Year: 1998
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Lightbulb Re: Passive POE
http://www.flyteccomputers.com/detai...fBoCL n_w_wcB
This is powered from a battery (12V), and outputs the required 48V (802.3af)
Poe. If using this, the only connection to the OM5P-AN is the ethernet cable.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 16-01-2016, 21:02
Re: Passive POE
That will burn the radio up, it does not work on 48 volts. And its against the blue box note about injectors.
Unread 16-01-2016, 22:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Passive POE
Also, 48 volt circuitry is not legal at all.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 16-01-2016, 22:56
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Passive POE
For the record, all PoE is 44v or greater - the radio will absolutely work on 48v IF THE 48V IS BEING SUPPLIED BY A POE INJECTOR INTO A POE-COMPATIBLE ETHERNET PORT. This is in no way suggests that putting 48v into the standard power connector will result in anything but a crisped radio, but plugging a PoE injector into the radio will work just peachy. It is, however, specifically outlawed in the rules - since there isn't a 48v source on the robot, you need an active power converter, so even if you take a DC/DC converter and strip the Ethernet cable to give 48v to the radio, all you will have done is created your very own custom injector, which is illegal.
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 16-01-2016, 23:52
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Passive POE
Wrong. 802.3af POE perhaps, but as the acronym stands for Power over Ethernet, any power provided by an Ethernet cable qualifies, hence the labeling on one port of the radio "18-24V POE".
Unread 18-01-2016, 06:52
Sparks333's Avatar
Robotics Engineer
AKA: Dane B.
Re: Passive POE
Hello!
The argument is primary a semantic one, and I doubt I'll convince you otherwise, but its implications are important enough I think I'll disagree with you.
PoE is an acronym, certainly, but it alway, ALWAYS, refers to 802.3af. That's how standards work.'Passive 12-24v PoE' is not a standard, it's a proprietary interface developed by OpenMesh and Ubiquiti that allows for power over ethernet, but, and this is important, it's not PoE, despite meeting the definition. When something says it supports PoE, it means it supports af, end of story. For the record, I've worked as an engineer in wifi testing and have contacts in the networking industry - I'm hip to the lingo.
https://www.open-mesh.com/poe/
Sparks
Unread 18-01-2016, 14:40
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Re: Passive POE
Hello!
Sparks
Out in the the real world there are a plethora of devices using nonstandard voltages for PoE. The devices are marketed as POE devices. I sympathize with you only wanting to call only 802.3af devices POE, but be aware that others don't follow your desires.
The blue box is strangely worded, but it does appear to allow you to supply the radio power from the VRM to radio thru the Ethernet cable.
If you don't know what you should hook up then you should read a data sheet
Unread 18-01-2016, 16:10
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
Re: Passive POE
Just pointing this out, but it seems that this has never been illegal to begin with! Passive POE is, and has been, legal because the passive injectors are basically cable splices with nice housings around them. There is no rule against splicing ethernet cable or adding additional connectors to your wiring. The only difference this year is that the radio has the ability to eliminate one of the splices.
Unread 18-01-2016, 17:01
Re: Passive POE
The rule says you can use the conductors. So this device from Adafruit ID: 435
would work and be acceptable. I've used this at events to be able to remotely power a switch that is not near an outlet.
This device is from the Open Mesh, it puts power onto the Ethernet Cable. It lets you feed any power voltage.
If you look at the connections on the switch, there are two ports.
So in theory you should be able to use the Open Mesh POE insertion device, power it like you would the radio directly. Plug the other end of the ethernet cable into the POE-18-24V plug.
My question would be does the Open Mesh Insertion device qualify as a way to use the extra wires in the ethernet cable? I would think so, since it's supported by Open Mesh. But you would need to submit it as a Q&A question.
@Daniel_LaFleur We've had ethernet connections on the robot for years. Most people put strain relief near the ends to keep an errant game part from taking the connection out.
I've seen/heard of teams that had problems, in every case the tab on the connector has been broken. The connector has decent metal to metal connections so as long as it's plugged in it should be good. While we all love a screwed in connection, can you talk more about connectors actually coming apart?
Unread 18-01-2016, 07:27
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Re: Passive POE
802.3af is an industry standard that uses ~48vdc, supplies 15.4w, and uses as a minimum cat3 cable
802.3at is an industry standard that uses ~52vdc, supplies 30w, and uses a minimum cat5 cable.
"18-24v POE" is non standard. It will only work with devices specifically designed for it and will probably burn up if used with standard PoE. Use at your own risk.
Back to the OPs post: I would not use PoE on a mobile robot because the RJ45 connector is not robust enough for the vibration our robots see.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 18-01-2016, 12:32
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
Re: Passive POE
I agree, but I still believe it's better than a standard barrel jack connector. Also, using passive injectors seems to be much easier than dealing with the af standard. The cable length we're talking about here is ~5 ft max which equates to ~0.4 V drop @ 1 A load. Passive injection is perfectly suited for this.
  #15   Spotlight this post!
Unread 18-01-2016, 12:48
phurley67 phurley67 is offline
Programming Mentor
FRC #0862 (Lightning Robotics)
Rookie Year: 2013
phurley67 is an unknown quantity at this point
Re: Passive POE
I am just a software guy, but don't we already depend on an RJ45 connector for the very vital connection between the RobotRIO and the radio, so how would using it for power make it worse? Do the RJ45 cables bounce more than the barrel connector and arc inside the housing? (genuinely curious, I had previously thought it would be a win)
