Go to Post I am a mechanical engineer. I have known since I was about 12 that I wanted to make complicated mechanisms. - Paul Copioli [more]
Unread 15-01-2016, 20:31
mark219 mark219 is offline
Programmer/Driver
AKA: Mark Szewczuk
FRC #0219 (Team Impact)
Rookie Year: 2015
mark219 is an unknown quantity at this point
RobotMap?
Is it proper to use the class RobotMap...? I know that RobotBuilder gives it to you or default java code gives it to you when you create a new java project but I just don't see the point in having it other than organization. Any insight on why it should/shouldn't be used?
