Go to Post Once you know where you want to go, you can decide how you want to get there. - sciguy125 [more]
Unread 01-16-2016, 02:56 PM
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
LiveVision broken with Java
Just checking out new tools. Load Java robot project into roboRio; when we throw it into test mode, the Java SmartDashbaord just goes blank.
We've scratched the old save.xml for SmartDashaboard; that didn't help.
Having the same problem with 2 different PCs.
Has anyone else seen this?
Unread 01-16-2016, 05:53 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: LiveVision broken with Java
I assume you mean LiveWindow?
It works with our 2015 robot code ported to 2016. If you run Smartdashboard from the command line, is there anything printed when you switch to test mode?
Unread 01-16-2016, 08:32 PM
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
Also, there was an update yesterday that fixed a few crashing issues in SmartDashboard. Can you ensure that your tools are updated? (Eclipse -> Help -> Check For Updates)
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
