Go to Post You have to start at the bottom to get to the top, usually. - Kyle [more]
Unread 16-01-2016, 16:13
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Once the tower is weekend <1 strength the Flag drops Will the flag raise If <0
After scoring enough boulders to weekended the tower [Tower Strength = <1] If an alliance receives a fowl adding one tower strength bake to the opponents tower [Tower Strength now = >0] will the flag raise back up signaling the tower can NOT be captured at the end?
Unread 16-01-2016, 16:18
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Once the tower is weekend <1 strength the Flag drops Will the flag raise If <0
I would assume so. However, your definition of Weakened needs work.
A Weakened tower has a Strength of <1 (or, if you prefer, <= 0).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-01-2016, 16:26
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Rookie Year: 2013
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
I posted a Q&A question regarding this this morning, and it was just answered. Copy-pasting for reference (Q567)
"Per Section 3.1.4: "A TOWER is WEAKENED if the TOWER’S STRENGTH is at or below zero (0)." If you earn a TECH FOUL and the STRENGTH is increased from zero(0) to one (1), the TOWER is no longer WEAKENED. If the TOWER'S STRENGTH is -1 (negative 1) and a TECH FOUL is assigned, the STRENGTH is increased to zero (0). In this case, the TOWER would remain WEAKENED."
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
2013-2016: Team 610
2017-????: Team 4476
Unread 16-01-2016, 16:34
Rookie Year: 2015
coders syntax the IDE would have gigged me.
But Thank you for posting the question today and relaying it here.
